This question is about speakers being able to produce an illusion of musical instruments being located at exact positions in the room when listening to music. I have heard that designs like elac fs137 jet (which is test-winner in the 1000 Euso-class) may have problems in this respect if the bass/midrange-drivers are separated too much.
Has anyone evaluated this for elac fs137 jet or on similar designs? How does the mentioned ability depend on the distance between the bass/midrange-drivers? |
#2 |
Please, follow the link below for additional information on the speaker:
http://www.elac.com/en/products/clas...f/fs137jet.pdf |
#3 |
Seems a perfectly soundly(sic) designed 2.5 way. The MT c/o at 2.5kHz is fine in terms of spacing issues. The bass to mid 0.5 c/o point has no spacing issues at all. |
#4 |
Thank you sreten,
have you listened to this kind of designs and found them to produce a precise "image" of the sound? |
#5 |
I've not listened to them in your terms. A 2.5way should be the same as a 2-way. 140mm driver + small tweeter is close spacing. To me there is no this "kind" of design, not enough detail. There is good design and bad design, bad sounds poor. |
| FS: Elac S517, 8" Alnico Full-range Driver / Pair | speaker | Swap Meet | 1 | 30th July 2009 04:30 AM |
| Looking for one ELAC jet tweeter. | Miab | Swap Meet | 0 | 26th March 2009 05:15 AM |
| Elac's new fullrange driver.. | ScottG | Full Range | 0 | 29th August 2007 11:36 PM |
| ELAC help | day | Multi-Way | 1 | 8th March 2005 02:32 AM |
| Vintage Elac Drivers, Any info anyone? | Grumpy_Git | Full Range | 2 | 9th January 2005 07:49 AM |
| Page generated in 0.06786 seconds (74.54% PHP - 25.46% MySQL) with 10 queries |
