Crossover Types and Polar Response?
Old 24th January 2009, 09:13 PM   #1
Tenson is offline Tenson  United Kingdom
Default Crossover Types and Polar Response?
I remember some time ago reading a webpage that compared different crossover types and also showed their polar response in the vertical domain (in a vertical driver alignment). I can't find it now, does anyone now what it was?
I am thinking of building a MTM design and from memory this webpage showed that, in a MTM, a 3rd order butterworth filter had wider vertical polar response than a 4th order LR.
However I don't think 3rd order will be steep enough for my design idea. Would a 6th order Butterworth have the same effect?
Thanks!
Old 25th January 2009, 08:24 AM   #2
jlo is offline jlo  France
Hi, you can use this (free) software to simulate your driver positions (MTM or others) and crossover types. Then listen to the result in realtime when you move listening position and angle.
XOralizer
jl ohl
ohl about audio
Old 25th January 2009, 10:32 PM   #3
Thanks Jl,
That program is nice but it doesn't seem to support 6th order crossovers? Any chance you could quickly add this for me?
It seems looking at the program that despite 4th order LR having sharper filters, the 3rd order butterworth manages less off axis suckout on a MTM design. So can anyone confirm if a 6th order Butterworth has the same advantages? You see I can't really use a 3rd order as it won't protect the drivers enough. So I can use a 4th order LR design, but if a 6th order Butterworth will give less suckout not just because of the sharper filters but also because of the phase interaction then I will go for that. Comments?!
Old 25th January 2009, 11:01 PM   #4
Drew Eckhardt is offline Drew Eckhardt  United States
Without inputs for wall locations and absorption coefficients it's not going to give a good idea of how the speaker sounds in-room.
The spectrum of early reflections and reverberant field which are a product of the room and polar response have a lot to do with what a speaker sounds like in a domestic environment.
For example, I'd speculate that the broader but shallower power response dip explains the difference most people hear with a first order cross-over versus LR4 given that they can't hear the second order all-pass of a 4th order Linkwitz Riley filter applied by itself.
Old 26th January 2009, 02:13 AM   #5
Ron E is offline Ron E  United States
Ron E's Avatar
Default Re: Crossover Types and Polar Response?
I believe you will find that even order crossovers are symmetric and odd are not. The nonsymmetric nature is what somewhat evens out the polar response of a 3rd order MTM. There are still off axis aberrations in any MTM that are not related to the crossover, and the sharper the crossover, the less lobing problems you have because the bandwidth where the drivers interfere is less. I don't think lobing errors merit going to 6th order.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 26th January 2009, 02:17 AM   #6
a.wayne is offline a.wayne  United States
Sin Bin
Odd order is best for MTM layout ...................
Old 26th January 2009, 04:00 AM   #7
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Rememer to time align all drivers on the box design, or you may need both even and odd order xo...well, may still do anyway
The real important things happens on the acoustic side
Not possible to say exactly how filter will turn out before the design is playing
sometimes we know very little, and sometimes we know too much
Old 26th January 2009, 01:37 PM   #8
Default Re: Re: Crossover Types and Polar Response?
Thanks guys, that is what I needed to know. I will aim for a 5th order Butterworth then.
Crossover Types and Polar Response?Hide this!Advertise here!
MTM with BW3 and LR4 - Polar response HiFiNutNut Multi-Way 2 26th February 2008 08:52 PM
woofer in 2.5 way affecting polar response thadman Multi-Way 0 15th June 2007 04:49 PM
Beaming effect on polar response at crossover tiroth Multi-Way 13 3rd July 2004 10:25 PM
Can I make a Non-Polar Electrolytic using two polar ones PaulHilgeman Parts 6 10th February 2003 12:07 AM
Electronic Crossover for DIY Response 1sc Rachel Solid State 2 10th January 2002 04:07 PM
