Old 24th January 2009, 08:17 PM   #1
Default affordable 6ohm bass/mid driver
Hi, i hope i am posting in the right area, i had a look and couldn't find a similar thread, i am trying to create a pair of speakers for practically no budget, i have a pair of small cabinets that had awful drivers in but seemed ok so i went about the process of replacing parts, i put in a pair of peerless sr19dt's and that made a huge difference but now i need a pair of 5" bass/mid drivers that are 6 ohm and not going to cost the earth, any help would be greatly appreciated.
Old 24th January 2009, 08:51 PM   #2
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
there are many 5"... can you put a numer on "practically no budget"... for some this would mean $5, for others $500
Old 24th January 2009, 09:13 PM   #3
Why 6 ohm?
I'm assuming it is because your existing speakers are rated at 6 ohm, and I'm assuming that the reason you want 6 ohm is so you can continue to use the existing crossovers.
However, a 6 ohm rating for the overall speaker system, doesn't mean ALL the drivers are 6 ohms. It is conceivable that it uses an 8 ohm woofer and a 6ohm tweeter, which means because of the tweeter, the system as a whole would likely have an overall 6 ohm rating.
Using a more extreme example, if you have a speaker that has a 4 ohms woofer, 8 ohm midrange, and 16 ohm tweeter, the overall system rating would be 4 ohms, because as some frequency the impedance will drop down into that range.
Also, how about a description of the existing speaker system? Is it a two driver 2-way design, or a three driver (MTM) 2-way design? Or what???
We can probably point you at a 6 ohm driver, though not that easily as they are typically 4 ohms or 8 ohms. But that doesn't necessarily solve your problem.
Again, how about a more accurate description of the overall speaker system, and if possible brand and model?
Also, do you have any sense of what the existing crossover point is?
Steve/bluewizard
Old 24th January 2009, 09:17 PM   #4
tinitus is offline tinitus  Europe
http://www.bmm-electronics.com/Produ...roduct_ID=3348
Peerless, 16EUR
http://www.bmm-electronics.com/Produ...roduct_ID=2018
Visaton, 19EUR
VERY fine small midwoofers
I guess postage cost the same
Good luck
Old 25th January 2009, 12:02 AM   #5
Hi, sorry, for a pair i would like to spend £50 maybe £75.
Old 25th January 2009, 12:02 AM   #6
i did indeed think that both drivers should be rated 6 ohms, but if i can in fact use an 8 ohm mid/bass then that would make things simpler, unfortunately there is no manufacturer details on the cabinets so i have no info to give there but the dimensions are w19cm d19cm h30cm and they are rear ported, pretty small cabinets really, i use a musical fidelity b1 amp if that helps,
thanks for the links tinitus, that looks like a good place to start
i have been looking at some monacors but discounted them as they were 8 ohm.
Old 25th January 2009, 01:53 AM   #7
8ohm is average
DC is around 6ohm
The two I linked to are best fore your box if closed, hard to find any better, those are fine drivers
The next level is Peerless and this 5" Nomex may be among the best fore midrange in bigger speakers, very high quality
Also it suits your box perfectly if basreflex, very nice
Good thing is that its still one of the cheapest among better drivers
http://www.bmm-electronics.com/Produ...roduct_ID=4292
Old 25th January 2009, 03:58 AM   #8
perempe20's Avatar
Peerless, 16EUR
It's a steal.
Old 25th January 2009, 09:39 AM   #9
I'm very happy with my peerless tweeters so i think i'll try the peerless drivers too,
Thank you all for your help.
Amplifier for 6ohm speaker no183 Pass Labs 12 5th June 2009 07:02 AM
What's the affordable 100dB+ Fullrange driver ? calico88 Full Range 62 2nd October 2008 10:21 PM
6ohm tweeters wiredmonkey Multi-Way 7 10th May 2008 09:24 AM
LM3886 parallel for 6ohm Dxvideo Chip Amps 11 7th April 2007 08:38 AM
Page generated in 0.10490 seconds (78.73% PHP - 21.27% MySQL) with 10 queries
