Old 23rd January 2009, 06:36 PM   #1
Default Help with choosing first kit
hey all!
i've been lurking around the threads for a while looking for a great reference music monitor for my apartment. I soon came to relize that there are an overwealming amount of projects to choose from. From carful consideration, I narrowed the criteria set to three different projects and I need help making the final decision.
1) UA701 from usher audio and partexpress. I've herd great things about these scanspeak clones
2) Wonder or System 7 from zalytron using the focal drivers from the utopia line. I dont know much about them except that they are good performers
3)ZA-SR71 designed by zaph audio for madisound. I've herd nothing but good things about these too.
I am guessing these speaker kits are all very good, but what are the best? Music I listen to consists of everything but rap. thanks!
Old 27th January 2009, 09:06 PM   #2
anyone?
Old 27th January 2009, 11:47 PM   #3
infinia is offline infinia  United States
infinia's Avatar
Hi
Out of the 3 similar designs you listed, I would recommend the first, mainly because of the designer and the drivers used (esp mid bass) are very high quality and are a little better value.
You could also get a more complete kit if you don't want to do the woodwork.
Choices 1 and 3 to are close in spec but have a different designer.
Choice 2 is the same designer but should have less bass and output even if I knew the overall spec.
Usher 701 Speaker Kit manual
http://www.parts-express.com/pdf/302-953m.pdf
Order page
http://www.parts-express.com/pe/psho...53&ctab=5#Tabs
P.S. Beware there are folks that offer untested mods and part substitutions for these... I suggest to built it exactly as designed in the manual. The Cone geometry is part of the crossover design for offaxis respose.
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
A little help choosing an amp Williham Solid State 22 10th June 2009 07:35 PM
help on choosing a 1kw amp or better Hayden Solid State 5 17th September 2006 01:25 AM
Need help choosing a amp Dysturbed_90dx_ Car Audio 5 22nd May 2004 10:53 AM
Please i need some help choosing an amp. mindless_bg Chip Amps 8 4th May 2004 12:22 AM
Page generated in 0.07294 seconds (72.08% PHP - 27.92% MySQL) with 10 queries
