what do you guys use for a crossover board?
not looking for anything permanent or fancy as this is true budget and the components would probably end up getting changed quite often. i've looked at the boards from solen and madisound. though those seem to be 2way 6db or 12db which wouldn't work in this case. |
#2 |
If you're not aware of the complexities of designing and building and modifying a crossover, then don't even dream about starting this project.
Buy a kit that is already sorted or adopt a design of repute.
regards Andrew T. |
#3 | |
Either way, I appreciate the response but I dont think you understood my question. |
#4 |
I understand your question,
But I question your ability to take on this design challenge.
regards Andrew T. |
#5 |
Speakerholic
I use plywood.
Drill holes and use zap straps or twist ties instead of hot glue if you are planning to rearrange things. |
#6 |
Look at how this guy does it about 3/4 the way down his Artemis page:
http://home.versatel.nl/chiararomee/diy/indexeng.htm
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#7 |
Common pegboard, available at any building supply store, usually 1/4" (okay) or 1/8" (better) thick, already full of holes with regular spacing.
Andrew is correct that designing a xover is no easy task, but it's not impossible to get okay results with a lot of trials and testing and listening. Peace, Tom E |
#8 | |
#9 |
thanks for the replies guys.
pegboard is almost perfect. |
| When is a cross network more than a crossover board | mcmahon48 | Multi-Way | 8 | 15th March 2009 08:06 AM |
| crossover board repair | axiome | Multi-Way | 3 | 7th May 2008 09:56 PM |
| Active Crossover Board Group Buy | BobEllis | Group Buys | 86 | 30th April 2007 10:32 AM |
| Naim Crossover board SNAXO 2 way | macka | Swap Meet | 0 | 9th October 2006 07:13 AM |
| Page generated in 0.09435 seconds (77.16% PHP - 22.84% MySQL) with 10 queries |
