Old 24th January 2009, 08:12 AM   #11
jamikl is offline jamikl  Australia
Thanks for that GM. That is about what I figured was going on. Looks worth doing. the response is similar to a sealed box of the same size but as previously stated the xmax is smaller for a considerably higher Spl.
Fs 35 Hz
Re 6.23
Bl 11.5 roughly
Lvc 1.10
Qes 0.63
Qms 8.10
Qt 0.585
Sd 826.7cm^2
Radd 0.25 to 0.3
Expansions tried 0.7, 0.8 and 1.5
jamikl
fs 35Hz
smith horns and using compression horns for a Karlson party speaker project bikehorn Multi-Way 14 30th January 2013 05:20 PM
are these horns? tomtt Multi-Way 8 20th October 2006 10:07 PM
Frequency CUT and a HOLE in frequency range... -_nando-_ Everything Else 0 28th December 2005 08:17 PM
Horns: Vibrations and resonances in metal horns Rocky Multi-Way 10 28th July 2004 01:38 AM
What is the cut off frequency for the Altec A7 and A4 horns? Cal Weldon Multi-Way 11 21st January 2004 12:06 AM
Copyright ©1999-2013 diyAudio
