Old 21st January 2009, 03:54 PM   #1
Default low output tweeter Help!
I have some Tannoy Mercury speakers that have a really low output tweeter on one of the speakers. I have ruled out the actual tweeter by swapping with the good tweeter. It must be the crossover then? But what could go on a crossover to make the tweeter play with such a low output?
Thanks.
Old 21st January 2009, 04:22 PM   #2
homertooties's Avatar
Hi there
If you have checked with another tweeter and result is same
Then i would suggest a break in connection starting with input terminal
check for continuity from terminal to board,then wires from board to tweeter,normally crossovers for tweeters consist of capacitors to
block low frequencies ,resistors to limit current and attenuate tweeter to match crossover rolloff of all drivers and of course inductors,not sure whether you have positors in there like morduant short use...
Check terminals ,check cables ,check continuity of inductors and resistors if present ,and test capacitor with another anything up
to about 12 uf...
Do not ever connect tweeter to amplifier with out a capacitor in series
Hope this helps
if you strip it for parts keep them for years as soon as you get rid you will want them .....................
Old 23rd January 2009, 08:38 AM   #3
Well i checked everything and it all pointed to the crossover components in which i tested one by one starting with the cap then on to the small guage wire coil and voila! That is what it was. To replace this thin guage wire coil, would i buy it off the reel and then as long as it is the same gauge just cut it to the same length as the faulty coil?
Old 10th February 2009, 11:56 AM   #4
Hi yeh sure just use enammelled wire of same length as inductance increases in length also diameter of wire,so check guage of wire first...
Old 10th February 2009, 02:39 PM   #5
All done!
Thanks for all your help.
Tweeter help for Miller & Kreisell Tweeter 17500 merajsalek Multi-Way 4 3rd September 2008 03:41 AM
Reducing output of tweeter bawang Multi-Way 2 16th November 2006 01:27 AM
amplifier output impedence matching for tweeter ackcheng Multi-Way 0 29th June 2005 02:35 AM
high-output midrange and tweeter xplod1236 Multi-Way 48 8th July 2004 04:48 PM
Page generated in 0.08824 seconds (74.04% PHP - 25.96% MySQL) with 10 queries
