#11 |
So I put the putty in, I couldn't wait. I have three of the identical speaker, so I can do measurements between them.
I started by adding duct seal to the speaker frame. |
#12 |
I then put putty all over the plastic caps on the extrusion ( side with port shown here)
#13 |
Non port side
#14 |
This is the front panel of the speaker that screws on to the enclosure. As you can see, the tweeter is attached to this plastic mounting
#15 |
Internal stuffed. I added a little more stuffing as it was very loosely stuffed before.
#16 |
"Woofers" put in. The piece of foam(?) on the right has the underside of it cut out from the aluminum, I can't figure out why they would do that, I guess that it could stop resonances?
#17 |
Final pic for today, the speaker on the table.
#18 |
I am trying to find a good place to upgrade the part on the pc board. Any good ideas?
How about any ideas on damping/cleaning up the speaker? There is a large difference between the tweeter volume and the woofers, is there an easy way to mute this? |
| What Modifications can I make? | dmongrain | Multi-Way | 0 | 21st January 2009 01:46 AM |
| NHT 3.3 Modifications | SY | Multi-Way | 22 | 22nd June 2008 05:12 AM |
| DAC-in-the-Box modifications. Again. | Aleksunder | Digital Source | 1 | 19th July 2007 03:10 AM |
| Zen V4 modifications | pro | Pass Labs | 2 | 31st August 2004 05:19 PM |
