The construction of a multicell horn
Old 22nd January 2009, 06:59 AM   #21
coresta is offline coresta  France
coresta's Avatar
Hej Petter ! very nice work indeed ! 5 years ago , i was on the way for the same project ... I finally found a pair of 805 B on ipay first reason : smaller have a narrower dispersion for private rooms : i don't have a theater at home .. second reason : copper soldering is easyer than wood working for a later tarfilling .last: a solid throat is very very important as this part gets the hard pressure from driver and shall not twist in any case . The 805 has brass throat that sounds better than aluminium ones ... cheers Pierre, from Paris too
Old 22nd January 2009, 07:06 AM   #22
Jmmlc is offline Jmmlc  France
R.I.P.
Hello Petter,
The Onken 15 cells horns are longer and possess a lower acoustical cut-off than the Altec 1505.
Best regards from Paris, France
Jean-Michel Le Cléac'h
Originally posted by Petter Persson
And every one else this Onken, is it simular to the Altec 1505B? The roof horns are awsome! *Want a house...*
/Petter
Old 22nd January 2009, 04:46 PM   #23
Pano is offline Pano  United States
Pano's Avatar
Wow! Amazing work Petter. Bravo!
That is very inspiring. Thank you for the lovely pictures and the step-by-step. I especially like the glue ring clamps.
You must be very happy with the sound.
Jean-Michel,
Merci pour la photo. Sacré Hiraga!
I borrowed his 15 cell Altec horns a few times, but I have not seen those Onken. The ceiling horns are great!
Old 22nd January 2009, 05:08 PM   #24
Cal Weldon is offline Cal Weldon  Canada
Speakerholic
Cal Weldon's Avatar
I'm with you on that one Michael, commonplace for others but a stroke of genius to me.
planet10 needs your help:
Let's help Ruth and Dave
Old 22nd January 2009, 08:13 PM   #25
Pano's Avatar
Yes - very clever! And simple.
The build reminds me a bit of wooden organ pipes.
Always wondered how the vertical joins were done and filled. Now I know! Simple, too. Thanks to Petter for showing us.
BTW, 200 hours of build time @ $20 an hour = $4000 (+materials). Not bad.....
And speaking of home made wooden multicell horns, has anyone else seen this guy in Florida?
http://www.chaudioroom.com/Sculpture.html
http://www.chaudioroom.com/Lportal.html
Beautiful stuff!
Old 24th January 2009, 06:51 AM   #26
vuki is offline vuki  Croatia
vuki's Avatar
Bravo Petter! You are making it look so easy to do. Wonderfull!
Old 6th June 2009, 12:11 PM   #27
timothygurney is offline timothygurney  France
Could you provide the horn profile?
Tim
Old 6th June 2009, 01:49 PM   #28
GWEE is offline GWEE  United States
this is one of the coolest things i have ever saw.....
Old 7th June 2009, 04:57 PM   #29
Speakerholic
Cal Weldon's Avatar
Yes it would be nice to have an update on these. I am still in awe Petter.
Old 10th October 2009, 08:21 AM   #30
Petter Persson is offline Petter Persson  Sweden
Hi All!
Sorry it took so long to update.
Thanks for all nice words!
CLS
One question: I saw it's a curved 'surface' where the multi-cell joint together near the throat. However the adaptor between horn and driver has 2 flat flanges. How is the conversion between the curvy side and the flat side?
See here, from page 1, A flat batten, 18 mm thick were mounted on the
throat side of the cells. The curve caused by the cells is quite small, so this
was a convinient approximation so the adapter could be attached.:
So, what´s new? The multicells and Kugelwellenhorns are intact, but the
midbass has been elongated at the throat by 66 mm resulting in higher
compression and smaller rear chamber (30 liters -> 12 liters). The mids were
initially made for 15", but due to economy and availability i had to use my
JBL 2202H instead, and they actually work great.. The longer horn and
smaller rear chamber gives a more direct and punchy sound and than before.
The Multicells and KW-horns were moved back 66 mm to correct phase.
New tapped horns were alse built, only five weeks ago. 400 liter netto, and
500 liters gross volume, using the same driver an in the old tapped horns,
JBL 2202H, the same as in the mids. Frequency response are really nice for
a single fold and they sound terrific with a firm low end which really matches
the rest of the system.
Proud
Simulation, corner placement
[IMG]http://proxy1.pixbox.se/arkivet/synligt_35/29100000-29109999/640x480/29108702.jpg?0[/IMG
Measurement, 2 pi, outside unsmoothed. Corner placement in room, they have full output down to 25 Hz. Crossed 24 dB/octave at 90 Hz. In the corner, unfiltered, the plateau over 100 Hz is only 3 dB above the 30->70 Hz range, compared to the outdoor measurements 6 dB. The level is not calibrated.
And the final result:
A bit more cosy, but with the old TH:
Due to wide angle lens, it appears that the drivers are not aligned vertically.
This is not true, they are placed straight on top of each other and and
corrected in depth for phase alignment.
I´m a bit prejudiced but it actually is one of the best I ever heard, and so
say people who comes here to So, if you´re ever come to Sweden, sen me a pm.
The construction of a multicell hornHide this!Advertise here!
How to DIY a wooden multicell Horn Jimmy DIY Multi-Way 11 1st October 2008 08:32 PM
horn construction concerns... Nanook Full Range 0 8th September 2007 03:17 AM
Construction technique straight horn mashaffer Subwoofers 5 14th June 2006 05:25 PM
