The construction of a multicell horn - Page 14 - diyAudio
Old 9th February 2013, 06:03 PM   #131
thedubemaster's Avatar
I finally got the spreadsheet if anyone wants to PM me I will be happy to send it to them. Cheers
Old 29th May 2013, 08:13 PM   #132
wesayso is offline wesayso  Netherlands
wesayso's Avatar
Digging trough the top rated threads I stumbled across this awesome build.
Looks like a fun project! Glad to see most pictures were recovered.
I wonder how many of these DIY multicells were build. Great stuff!
Old 5th June 2013, 01:03 PM   #133
Yes i know i'm very late to tell that's an awesome job Petter !
very impressed !
Franck (from Lyon)
Old 30th June 2013, 12:20 PM   #134
Couple days ago I was listen multicell horns and liked sound depth from them. I do not know much about horns, so I have question. Is it posible to build upperbass multicell horn? I mean 125hz 4" throat with back chamber for 8" driver. Is this could work?
C
Old 30th June 2013, 01:39 PM   #135
Pano is offline Pano  United States
Pano's Avatar
I don't see why it would not work. It will be big, though. For 125Hz usable it may need to be ~2M wide.
Take the Speaker Voltage Test!
planet10 needs your help: Let's help Ruth and Dave
Old 30th June 2013, 01:47 PM   #136
Is there any calculator for multi cells? 2m wide is not a problem, but what will by with lenght?
Old 30th June 2013, 01:52 PM   #137
GM is offline GM  United States
GM's Avatar
Sure, though probably mostly a waste of time without a proper phase plug, filter chamber though.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 30th June 2013, 02:09 PM   #138
Pano's Avatar
Thanks GM, I suspected the results wouldn't be great without a phase plug.
Old 7th September 2013, 10:27 AM   #139
Default Thanks petter
Very nice horns you did, would you give out the measurements to cut out the wings?
Why did you not make the altec horn?
i myself have such horns and play them with Altec 802D, down to 500Hz, and below Tannoy Monitor Gold in Lancaster Cabinets provide the bass
Josef
Old 14th September 2013, 03:45 PM   #140
Petter, your horn construction is incredible! I have always wanted multi cells, but
can't afford what they get for them on ebay. This would be a wonderful winter
project for me. Are all the specs contained in the pictures or do you have some
measurements that are needed. sure could use all the help I could get. rustirich
How to DIY a wooden multicell Horn Jimmy DIY Multi-Way 11 1st October 2008 08:32 PM
horn construction concerns... Nanook Full Range 0 8th September 2007 03:17 AM
Construction technique straight horn mashaffer Subwoofers 5 14th June 2006 05:25 PM
Copyright 1999-2017 diyAudio
