New audio system for my 'puter
Old 21st January 2009, 05:22 PM   #11
tigh4life is offline tigh4life  United States
Originally posted by planet10
And likely a whole lot better...you'd be hard pressed not to be able to build a better sounding speaker than those... even if your budget was only $30-40.
For instance, you are a car guy -- ever get any of the GM/Delco 6x9s as a trade-in or left-overs from an install...
dave
So let me understand this correctly. If my budget was only $30-40 i could build a better sounding speaker than the AV-40's?
The ol Delco paper cone x9's. Hook one up to 120v and see what it does then. Thatll brighten up your day!
I liked to see peoples face when i show them what exactly a bose speaker is made of and why the dealership charges them $400 to replace a single speaker!
Old 22nd January 2009, 03:04 AM   #12
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
The speaker... you'd still need an amp (but even a $10 thrift store find is likely WAY better).
$200 retail wit amps, so they are likely paying less than $10 in total for the drivers. Looks to be a thin injected moulded cabinet, with money spent on jewlery... as long as you paid attention to what you were doing, it shouldn't be hard.
And don't you dare connect one of those GM Delcos to 120VAC... it would be a shame to let the smoke out of such a nice driver (everytime i find a air at a garage sale for $2 or $5, i think some schmuck likely spent over a $100 to replace them with some tri-axial that didn't sound as good)
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 22nd January 2009, 03:30 AM   #13
frugal-phile(tm)
planet10's Avatar
Originally posted by mhelin
Regarding drivers also this new TB might do the job:
I have a set of 1 off 3" that use a similar basket & the neo magnet... they are gorgeous (and they sound pretty good too)
dave
Old 22nd January 2009, 04:06 AM   #14
well i was thinking of buyin the amp6 like some1 else suggested. And building a set of mfonken's. What type of driver do you suggest? Shielded or non-shielded? I love the look of the TB W3 or W4 style series fullranges. But if there is a better built/sounding speaker please lmk.
Old 22nd January 2009, 04:28 AM   #15
frugal-phile(tm)
planet10's Avatar
To build an mFonken you need FE127eN, FE127 if you are on a tight budget and can live with the reduced performance (still good sounding)
dave
Old 22nd January 2009, 04:34 AM   #16
there is no budget for good sound. but im not gonna get crazy! Ill order some FE127en. Do you suggest mfonkens? or somthing diff?
Old 22nd January 2009, 04:41 AM   #17
despotic931 is offline despotic931  United States
despotic931's Avatar
Send a message via AIM to despotic931
dave
Wow, so I'm not the only one who thinks those old delcos arn't bad? lol, my first speaker I ever built back in highschool was using a pair of those 6x9's, mainly because it's what I had. The cabinet is completely the wrong size because I didn't know any better, but recently I pulled them out of storage, took the back off the cabinets, and discovered they didn't sound half bad that way! Here they are sitting on top of my Sansui 4 ways (good for playing loud!)...
-Justin
Old 22nd January 2009, 05:57 AM   #18
frugal-phile(tm)
planet10's Avatar
TRhe mFonken (with FE127eN) is a giant killer (if i do say so myself) -- from our comparisons directly to a set of Rogers LS3/5A, a step above (and more efficient). The design gives up bass and a little bit of openness to get the small size. If you could live with a full-size Fonken that is a step up, but it is over 4x the volume.
dave
Old 22nd January 2009, 05:59 AM   #19
frugal-phile(tm)
planet10's Avatar
Are they the 10 ohm or the 4 ohm. I have a decent sample set of measures.
dave
Old 24th January 2009, 03:44 PM   #20
dave
I honestly don't have the speakers with me at the moment (I recently moved and put them back in storage) I want to say they are 4 ohm though, I'll find out and get back with you dave.
-Justin
New audio system for my 'puterHide this!Advertise here!
What audio system do you have? hugobross Everything Else 78 23rd August 2015 03:26 PM
Detachable car audio system. v-bro Car Audio 5 9th January 2007 10:32 PM
car audio system needs help stephen22 Class D 14 13th March 2006 06:32 AM
5.1 audio system for PC Qub Everything Else 3 2nd February 2006 04:57 AM
System Audio 1270s Positron Multi-Way 0 14th June 2003 11:50 PM
Copyright ©1999-2017 diyAudio
