How Reliable Are McCauley Drivers?
Old 6th December 2001, 12:00 AM   #1
kelticwizard is offline kelticwizard  United States
Wizard of Kelts
diyAudio Moderator Emeritus
A DJ cyber-friend of mine just had two Eminence 15 inchers go on him during one gig. He is done with Eminence, even though up until recently he was their biggest booster.
He is looking for a new brand at a somewhat similar price, with reliability the number one issue.
I have heard good things about McCauley, but I thought that I would put it on the board to get some kind of feedback from people who have had extensive experience with pro sound.
Any other recommendations for pro sound drivers that are reliable? His amp is a 350 Watt BK Electronics amp, (made in Britain).
I appreciate any advice on this matter.
Old 6th December 2001, 12:50 AM   #2
Ignite is offline Ignite  Canada
Send a message via ICQ to Ignite
Most good quality drivrers don't break during normal operation. I'd imagine he was running them beyond thier specifications. Many of the eminence drivers currently on the market do not have particularily high power ratings. I recall seeing one 15 inch driver with a RMS power rating of 50 watts. I would want to check the power rating of the drivers he was using before blaming the drivers for the failure.
Old 6th December 2001, 01:03 AM   #3
Wizard of Kelts
Ignite:
They were Eminence Kappa 15-400 Watts. He plays them virtually every night -that is his business. They used to be reliable, but lately they are not. He has not changed his amp or done anything different to account for the difference.
Old 16th August 2011, 10:28 PM   #4
tiefbassuebertr is offline tiefbassuebertr  Germany
tiefbassuebertr's Avatar
8 years ago I have realized some sub bass projects with the 6258 in the kind as to see on the attached pictures. Until now no problems were noted.
Here the data sheet of the transducer:
McCauley.com : Products: Components > 6258: Overview
Old 17th August 2011, 08:36 AM   #5
CLS is offline CLS  Taiwan
Household usage is very different from PA.
2 pro sound 18" in a big box playing in an ordinary living room, I don't worry about any problem with the drivers. People in that house would have more 'problem' before the drivers.
ps. nice build.
Old 17th August 2011, 08:33 PM   #6
Erik F is offline Erik F  United States
Uh your friends amp is under powered that is what most likely blew up is shazel. Clipping your amp is the quickest way to speaker cone death. Also if he blew both I have to call user error.
Old 17th August 2011, 08:59 PM   #7
kevinkr's Avatar
This doesn't seem entirely unlikely, could a difference in music format - a change for example from classic rock to highly compressed rap/hip-hop or electronica be behind the issue?
The original post seems to imply that the particular eminence drivers were reliable but are no longer - this implies that there have been repeated instances of blown drivers starting with the original old "reliable" ones failing followed in quick succession by the new ones - this would point solidly at something other than the drivers themselves unless they were grossly under-rated for the task.
Next - what is the failure mode? Burned out VC, ripped spider or surround, shredded cone?
Is the box properly loading the woofer, is an HPF filter applied for below box/speaker cut off frequency in order to limit out of band excursion?
Amplifier verified to be OK, no DC on output, no oscillations, good clipping behavior - is this run full range or only woofers only? No problems with tweeters and are they powered by the same amp?
Keltic Wizard can you provide any further details?
It could be the Eminence Kappa drivers, but it would be shame to cook a pair of McCauleys for the same reason..
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 17th August 2011, 09:03 PM   #8
simon7000 is offline simon7000  United States
Or it could be a change to low volatile cements. I'd check with Eminence to see what they think. They are pretty sharp folks.
Old 17th August 2011, 09:12 PM   #9
kevinkr's Avatar
"Shazel" is a pretty obscure way of circumventing our censor, I like it..
Old 17th August 2011, 10:52 PM   #10
Ha. Also didn't realize this thread was form 2001. I've been out of the diy thing for a bit but have been getting the bug again.
How Reliable Are McCauley Drivers?Hide this!Advertise here!
www.thetubecenter.com = reliable? skyraider Tubes / Valves 4 22nd June 2008 12:49 AM
McCauley 12inch from EAW matze84 Multi-Way 0 20th February 2008 06:14 PM
Reliable B+ PSU for pro preamp rotation Tubes / Valves 1 30th November 2007 03:14 AM
Where to buy McCauley 6174? BHTX Subwoofers 2 4th August 2007 02:00 AM
Reliable news sources Hans L The Lounge 15 26th September 2004 03:58 PM
Copyright ©1999-2017 diyAudio
