I am trying to find Radio Shack tweeter 40-1377. They are very hard to find now. I built my own speakers years ago and used them, now I need one becuase one is blown. I am trying to find fboog because he may have one. Can any one help? Thanks
#2 |
frugal-phile(tm)
What do they look like.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#3 |
They are half spheres with a slot in the middle.
#4 |
Speakerholic
Can you post a pic or two?
#5 |
I know what ones your talking about. Good luck sourcing one. I believe that RS also used them in a model of 3 ways they had at the time. You may want to start looking to replace the pair. They've been gone from the RS catalog for close to 20 years.
#6 |
Speakerholic
This baby here?
#7 |
Speakerholic
#8 |
That would be them. At least the ones I'm thinking about. I'm sure those are the same as the OP is looking for.
#9 |
frugal-phile(tm)
I have 2 or 3 of those (well at least 1)
dave
#10 |
Here is a link to a better picture of the Mach TWO -
http://www.audiokarma.org/gallery/sh...&size=big&cat= First, is your speaker that Realistic Mach TWO? If you go to Radio Shack you can still find specifications on the speaker system. http://support.radioshack.com/support_audio/7269.htm The tweeter for the Mach 2 is listed as - 11088648 . . . SPEAKER,BI-RADIAL HORN . . . SP5413 Which does not seem to be the horn tweeter you referenced. Here is a list of all of Radio Shack's historical parts - http://support.radioshack.com/support_audio/17320.htm Find your speaker model there, and see if you can get details on the crossover points. For example - Listed in Features for the Mach 2 - "The 15" (38 cm) high-compliance woofer speaker faithfully reproduces rich bass from 25 to 800 Hz. The 5" cone midrange speaker gives exceptionally smooth response from 800 to 6,000 Hz." That implies the crossovers for this system are 800hz and 6,000hz. Which probably means you can use virtually any tweeter that will fit and has the same impedance. Note, in searching Google for the Mach TWO, I found several people in various forums who have Mach 2's that had blown woofers. If you can find one of these people who would sell you their tweeters, that might be a solution. So, what is the exact model of your speaker system? Steve/bluewizard |
| Radio Shack | BrianDonegan | Everything Else | 0 | 23rd April 2007 05:27 PM |
| Radio Shack OPT! | sorenj07 | Parts | 2 | 13th March 2007 02:30 AM |
| Radio Shack Super Tweeter | bbchem | Multi-Way | 10 | 16th October 2006 09:39 PM |
| Radio-Shack 40-1278B Radial Horn Tweeter | fireman | Multi-Way | 2 | 10th March 2004 12:56 AM |
| WTB Realistic (Radio Shack) 40-1377 Tweeter | fboog | Swap Meet | 2 | 10th December 2003 08:11 AM |
| Page generated in 0.09912 seconds (79.30% PHP - 20.70% MySQL) with 11 queries |
