Hi. I'm new to this diy speaker building community, but i am very interested and eager to learn.
I was wondering about a couple of things. I am going to be purchasing 2 audax hm170c0 6.5" woofers and 2 vifa xt25tg30 tweeters, and looking to build 2 way bookshelf speakers 1. I was thinking about making the cabinets about 15 inches tall (inside measurement), which using the golden ratio (1.618-1-0.618) the width works out to be about 9.25 inches (inside measurement). What should my depth be to maximize lower frequencies but not compromise mid and high? 2. I am open to suggestions for crossover design, as i don't know much about designing a crossover so help is much appreciated. 3. I know the audax hm170c0 has a db jump from 90db to 93db at about 600hz. Is that anything to worry about? And if it is, how would i regulate that? Audax HM170C0 datasheet vifa xt25tg30 datasheet Thanks for encouraging and helping a fellow DIY'er get on his way to attempting to build a great set of speakers |
#2 |
do you own, or plan to get decent measurement-equipment for this project? (If not, I would strongly suggest building a kit first, for example: Audax Pro 21 ) Regards, Micha |
#3 | |
At least you need to calculate box size...its the most simple thing, and its easy to find software Some are easy and simple, others are more complicated doing graphs and all As fore the last bit, I have to dissapoint you...thats not likely going to happen I suggest you find a proper design, designed and develloped by good skilled people...and learn from that http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm This one I dont know anything about...but sure looks good http://home.versatel.nl/chiararomee/diy/indexeng.htm And there several others |
| Speaker Suggestions for a Grado Fan. | Lewis Moon | Multi-Way | 8 | 30th September 2008 04:55 PM |
| Suggestions for first speaker project | tdstr | Multi-Way | 6 | 17th April 2007 10:14 PM |
| Speaker Suggestions for GC | dsavitsk | Chip Amps | 7 | 25th February 2005 05:36 PM |
| HTPC speaker Suggestions... | AZ_Ron | Multi-Way | 4 | 12th October 2004 07:39 AM |
| Speaker Suggestions! | Xavier | Multi-Way | 23 | 22nd October 2001 05:59 AM |
| Page generated in 0.07756 seconds (72.75% PHP - 27.25% MySQL) with 10 queries |
