weird T-line
weird T-line
Old 12th April 2003, 06:02 AM   #1
mikee12345 is offline mikee12345  New Zealand
mikee12345's Avatar
Default weird T-line
Find 1 philips 12inch (fs=44hz Q=0.19)
find a 8inch philips on a conical pipe.(43hz or so)
put the 12inch on the Mouth of the conical pipe.remove the 8inch speaker.
make a port,at the end of it (the old throat)
it is now a throat=0.6x Sd mouth= ? 0.2x Sd Decreasing area conical pipe!
listen to see if it makes any bass.
(mine doesnt make too much) the cone moves alot but just makes flapping noises. it makes quiet 50hz but the speaker can only take 40watts rms anyway,and is low excursion :-D.
how unscientific is that!
i think the speaker would work better in a ported box the same size lol.
i think i should have 4x Sd or somthing
il put that into the mathcad tl files :P
weird T-lineHide this!Advertise here!
weird old amp:need help bullpeters Tubes / Valves 1 6th May 2009 08:20 AM
Weird e_fortier Class D 3 4th July 2008 02:16 AM
Here is a weird one mashaffer Solid State 2 26th March 2006 01:23 AM
weird karma Everything Else 1 26th May 2004 04:10 AM
weird karma Everything Else 8 6th May 2003 11:42 AM
Copyright ©1999-2017 diyAudio
