Old 14th January 2009, 09:38 PM   #1
Lightbulb How to calculate an enclosure with variovent ?
Hello everybody,
I have these 15" with these specs :
and i would like to construct an enclosure for them with some variovent
So i would like to know few things :
- the approximate size of the box
-the number of variovent per box
-if there is another way to reduce the size of the enclosure without going to the ported soluton
Thanx
Old 14th January 2009, 10:29 PM   #2
nigelwright7557's Avatar
Look up WinISD.
This is a program that will help you.
http://www.murtonpikesystems.co.uk PCBCAD40 pcb design software.
Old 15th January 2009, 12:09 AM   #3
Ron E is offline Ron E  United States
Ron E's Avatar
Those woofers will not make any bass in a sealed box. Q is too low. If you want no bass, you can go as low as 15 Liters, for an F3 of ~160Hz. Variovents are not needed for this woofer to put it in a small box.
Personally I would think about 50-100Liter ported boxes tuned in the 40-50Hz range, or I would make some sort of Horn out of them. Bandpass might also be an interesting option.
What are you aiming for, what is the intended purpose?
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 16th January 2009, 03:46 PM   #4
RJ is offline RJ  United States
Default Re: How to calculate an enclosure with variovent ?
Originally posted by TomatoBangBang
Hello everybody,
Thanx
Here's some info I've gathered over the years.
If I have time today I'll run them parameters through Win Isd.
http://aperiodic-enclosures.blogspot.com/
Old 16th January 2009, 04:35 PM   #5
It doesn't look good or model well in WinIsd for Aperiodic loading.
Looks really good for a 4th or 6th order Bandpass, which probably means it'll also do well in a horn loaded design.
Modeling a variovent pjpoes Subwoofers 7 21st February 2007 03:17 AM
Help calculate enclosure volume Sillyboy Multi-Way 25 5th May 2006 11:22 PM
Variovent placement... arcturus Multi-Way 12 16th October 2004 03:46 AM
how do I calculate the sub box enclosure? Tony.ca Multi-Way 5 8th June 2003 12:05 AM
Opening a can of worms but...how do you calculate the slope inside a TL enclosure Rino odorico Multi-Way 17 26th August 2002 05:57 PM
Page generated in 0.11103 seconds (65.24% PHP - 34.76% MySQL) with 10 queries
