Home Forums Articles Gallery Blogs Register Donations FAQ Calendar Search Today's Posts Mark Forums Read
Thread Tools
Old 12th January 2009, 02:42 AM   #1
Default Proprietary Xover design?
Hi all,
i was wondering if there are any types of proprietary crossover designs either developed by diy or commercially or does everyone use the typical butteworth or linkwitz etc?
how does one (diy-er) choose which type to use?
thanks
Old 12th January 2009, 03:21 AM   #2
I suspect, at one time, Modafferi's INfinite slope crossover was proprietary.
Patent #7085389
http://www.patentstorm.us/patents/70...scription.html
It has been and is still used in a number of speakers.
The choosing of a crossover 'type' requires considerable knowledge of loudspeaker design concepts. Suggest you get your hands on a copy of Dickason's Loudspeaker Cookbook and study it for starters.
Old 12th January 2009, 10:03 AM   #3
forr is offline forr
forr's Avatar
Hi Auriches,
Have a look at these elliptic filters for crossovers :
Works well for me at 1.5 kHz (I prefer LR at 160 Hz)
The Best Active Crossover - Here!
NTM based on the same idea, more complicated
http://sound.westhost.com/articles/ntm-xover.htm
Implemented in digital processors under the NTM name for BSS.
With a little programmation, can also be implemented in XTA processors.
Old 12th January 2009, 08:53 PM   #4
gedlee is offline gedlee
The real point here is that the crossover filters have to be the total acoustic response - the electrical response is only part of the problem. So the electrical part of any competent crossover filter is not going to fit the "textbook" filter topologies. It's the final acoustic response that matters not what the electrical filters do. Transducers are anything buy simple devices and their response has to be part of the design. In general the electrical part has to be fit to them, not the other way arround.
Old 12th January 2009, 09:10 PM   #5
forr's Avatar
Another uncommon crossover :
Lecleach paper on crossovers
Of course, the transfer functions of loudspeakers have to be taken in account to get the intended repsonse. It's true for any crossover. However high slope crossovers are naturally a bit less sensitive to the out of band response non-linearities of the drivers.
Thread Tools
My 2 way design... need xover help AudioGeek Multi-Way 4 2nd April 2007 01:28 PM
Question about proprietary... mjarve Chip Amps 1 16th September 2004 12:46 AM
proprietary drivers joelives Multi-Way 4 12th June 2003 11:52 PM
Xover design help Kram Multi-Way 38 5th January 2003 08:33 PM
Series xover design ronjg Multi-Way 26 4th September 2002 07:25 AM
Page generated in 0.08280110 seconds (77.38% PHP - 22.62% MySQL) with 10 queries
Copyright ©1999-2010 diyAudio
