I have an old pair of speakers and I think that the tweeter needs to be replaced. Sounds still comes out but there is a "buzzing" with high frequency sounds.
The speakers are QLN and the tweeter is 2.5cm. The markings on the back say "Luxor Briljant" 2.5 cm 1458. I can't find any reference to their specifications on the net. How do I go about choosing the correct replacement? Any ideas? Thanks Jack |
#2 |
hello.
are there very old electrolytic caps in the frequency-network?have you tried to change them to new ones(bipolar type)? greetings............ |
#3 |
hello.
sorry "my english". freq.netw.=crossover netw. , bipolar=non polarised greetings.............. |
#4 |
Thanks for your response. Are you saying that the old capacitors could be the cause of the "buzzing" that I am hearing and that I may be able to solve the problem without replacing the tweeter? That would be great. I think I will try to replace the capacitors before I try to replace the tweeter. Let me know if this is correct. Thanks for you help. Jack |
#5 |
hello.
if the speakers are not damaged(rent in a cone or so),there is a chance to repair these .i presume there is a np-electrolyt in the signalpath(and not a foilcap). if this doesn't work -there is a great chance the speakers are bad.and the new caps can be used with the new speakers. greetings........... |
#6 |
or sometimes only a mechanical flaw:when a screw is loose........
#7 |
Thank you. I will look into tryng to replace the capacitors and let you know how it goes.
All the best Jack |
#8 |
Speakerholic
Swap the tweeters around first to see where the problem lies before replacing anything. A buzz is usually either from the amplifier or as mjf says, there is something loose. If the coil is damaged you will hear a scratching kind of sound.
| Looking for info onan unknown Tweeter model (M&K brand)? | JBCon | Multi-Way | 0 | 8th December 2008 06:08 PM |
| How to figure out unknown specs? | FlipC | Subwoofers | 7 | 17th November 2008 09:09 PM |
| what tweeter to replace a Kef t27 | helios999 | Multi-Way | 1 | 16th June 2008 01:55 PM |
| Unknown tweeter, (fostex?) help? | Cobra2 | Multi-Way | 8 | 16th April 2008 01:50 PM |
| Tweeter to replace Vifa TC25TF06 | Tenson | Multi-Way | 2 | 21st August 2006 11:19 AM |
| Page generated in 0.10019 seconds (72.94% PHP - 27.06% MySQL) with 10 queries |
