Old 7th January 2009, 01:31 AM   #1
Question replacement driver for Mission 710 cab
Hi DIYers,
just recieved a pair of M710s via eBay... with one blown driver!
Turns out to be an UIS (unidentifable speaker), cone frozen solid in
the magnet. Rather than fix it I want to replace it.
Looking for pointers from anyone with experience...
Did a bit of googling phoning and found that;
-Mission is now aprt of AIG, who no longer stock it nor can give any
specs, other than 710s used Peerless drivers.
-Wilmslow Audio sell one Peerless
(Polypropylene Cone Mid/Bass
Diameter - 210mm
Sensitivity (2.83v/1m) - 90dB
Impedance - 8 ohm
Nominal power handling - 150w
Free air resonance - 33Hz
Frequency range - 20Hz-5kHz)
for about £40 +pp
Searching around I found a few cheaper possibillities;
- http://www.solotechnic.co.uk HiFi woofer, aluminium frame, kapton
voice coil - 20cm (8"), 150WRMS
Price: Inc VAT: £25.86
Product Code: 902.430
Product Detail: Diameter 20cm (8")
Power rms 150W
Power max 300W
Frequency response 30Hz - 5kHz
Impedance 8 ohms
SPL 88dB
Magnet weight 1.1kg (40 oz)
Voice coil 7.5cm (3")
and
Premia Audio; 8.99 +pp
polypropylene Rubber edge Black metal chassis
Specification:
Impedance 8 ohm
902.195
Power max. 200W
Power rms 100W
Diameter (8")
Frequency response 30Hz - 8kHz
Magnet weight 990g (35oz)
SPL @ 1W/1m 90dB
Voice coil 5cm (2")
and
Electic City Wholesalers 12.50 +pp
8" 8ohm, PP cone
Rubber surround
Power max. 200W
Power rms 100W
Diameter 20cm (8")
SPL @ 1W/1m 90dB
Voice coil 5cm (2")
(Thiele Small Pars; Item No.902.208 Re 7.1, Fs 53, Qms 2.4, Qes
1.13, Qts 0.75Sd(CM2), Vas(L) 216, Cms(uM/N) 20, Mms(g) 300, B x 30,
L 7.9, SPL_1W/1m2 86 Prms(W) 100 Pmax(W) 200Xmax5)
So many choices! thing is I do't know enough about speakers, or even
all the Thiele Smalls of the original Peerless to try and make a
comparison (http://www.thielesmall.com lists a few, but none seem to
match even what little I have i.e. power, SPL, free air resonance)
Any clues, anybody?
BFN Steve
Mission Driver Specs HELP ME PLEASE - AAARRGGHH KIWIJARED Multi-Way 7 3rd May 2011 05:28 PM
Mission 770 Driver Replacement error401 Multi-Way 1 29th September 2008 08:32 AM
Mission 733 Woofer replacement? vonfilm Multi-Way 11 14th July 2008 08:16 PM
Need Cabinet for old mission driver's (Vifa) fin1bxn Multi-Way 2 1st January 2007 12:32 AM
Replacement driver Kittle Multi-Way 1 7th March 2006 06:51 PM
Page generated in 0.09045 seconds (69.50% PHP - 30.50% MySQL) with 10 queries
