Best way to attach a plinth (base) with lift to a heavy speaker?
I'm closing in on the final stretch on finishing a pair of Selah Audio RC-5Gs. I want to attached a plinth (base) to the speaker with a bit of a lift. That is, place a 1/2" finished riser board at the bottom of the speaker (this will be cut back about 1" or less from the speaker edge and is intended to separate the speaker from the plinth) of which I will then attache a piece of 1" thick hardwood as the plinth. Since the speaker is made of MDF which doesn't have a strong screw capacity I'm thinking people glue the plinth or use nut and bolt drilled all the way into the the bottom of the speaker? I'm just afraid over time of weakening the base through moving the speakers.
As an example of the look I am going for I like how Salk Sound does the base of their speakers and I am trying to do something similar:
http://www.salksound.com/ht3.shtml
Please let me know what you think would be the best way. I'm open to any suggestions/ideas.
