Old 6th January 2009, 12:39 PM   #1
angeloitacare's Avatar
Default a new horn speaker design in 3D
hi all
eventually i want to build this system this year.
The major concern is regarding the midbass horn placed in the mouth of the basshorn. I don't know if the diffraction would be negative , even if low frequency waves are not directional. The basshorn would cover up to 150hz.
more pictures and description at my forum
Angelo
Old 6th January 2009, 02:17 PM   #2
At least in a halfspace environment with the midbass horn sitting on the floor, you want the horn expansion to go the other way - to open up from the floor. Otherwise you immediately get a soundwave bouncing off the floor and causing cancellations at various points in space. I'm not sure how this would work in a small room at this frequency range, but I would still go the other way. Also, every time I have simulated that arrangement you show with a horn inside the mouth of another, it's been very bad at the mid to high frequencies of the bigger horn. At low frequencies the only problem (might) be that you are changing the exit area of the horn.
Old 6th January 2009, 02:30 PM   #3
hi John
thanks for your answer. i was thinking already of a alternative.
A shorter horn would have the advantage of 100% time alignment, but low end would be much weaker, and more equalisation would be needed, or a additional sub.
Angelo
Old 7th January 2009, 10:59 PM   #4
Default here a design with transparent horns
these could be made with acrylic resin casting. I am only wondering how these would behave acoustically. Ferguson Hill is the only manufacture i know, making such horns commercially.
Angelo
Help me design a horn unknownuser200 Multi-Way 23 2nd September 2008 01:14 PM
what's best enclosure design for Coral Beta 8 Speaker ? which horn ? Schematic ? calico88 Full Range 31 30th November 2006 07:38 AM
how to go from horn response to a folded bass horn design? paulspencer Subwoofers 8 4th November 2005 10:44 PM
Page generated in 0.08657 seconds (69.24% PHP - 30.76% MySQL) with 10 queries
