Old 5th January 2009, 08:47 AM   #1
Empee is offline Empee  Netherlands
Empee's Avatar
Default Question for TL-wizzards
Hello all !
I got a pair of 12" drivers with these specs:
Fs 30 Hz
Re 7.7 ohm
Qms 4.27
Qes 0.96
Qts 0.78
Vas 181 ltr.
Sd 0.049 m2
Mms 52 gr
Any care to help me on the dimentions for a (mass-loaded) TL ?
Tuned (very) low, as I intent to make a four-way
(sort-of like the Rogers Monitor / Pro 9 / Cambridge Audio R50)
Cheers, and thanks in advance !
Empee
In the end, all is good
If it's not good, it's not the end
Old 5th January 2009, 01:49 PM   #2
bjorno is offline bjorno  Sweden
Send a message via MSN to bjorno
Go for an Aperiodic ML-TL, tuned at 12-13 Hz :Internal dimensions: L48"xW14"xD16.5"
Port=4"dia: L=12", port stuffed with 22 (g) and the entire enclosure with 2.2 kg wool.
Driver at 32” and port at 42" from top, internal dimensions.
Se picture: 1(1)
b
1(1)
Old 5th January 2009, 02:52 PM   #3
qwad is offline qwad  Australia
l agree with bjorno, with those T/S parameters there is no way you can build a pro 9 tl or anything like a trad tl cheers T.C.
we all have problems only some people have more than most....
long live the Magyar (Hungarians) in the world!
Old 5th January 2009, 04:56 PM   #4
Empee's Avatar
Hi !
Thank you both, for your calculation and comment.
But regarding the outcome.... waaah !!
a cab (essentially a reflex, as I see it) of 181 liter is BIG, man !!
I thought TL's could have a high Qts
What would happen if one was to use such a high Qts in a TL,
boominess or just the other way around, lean bass ?
Cheers !
Empee
Old 5th January 2009, 08:05 PM   #5
Sorry qts around 0.27 to 033 is more suitable , l believe VIFA peerless and scanspek have sutable 12"drivers in their catalogue
cheers T.C.
Old 5th January 2009, 08:50 PM   #6
Empee's Avatar
Hi T.C. !
that's strange, on the t-linespeakers.org there is an article called "Martin J King for Dummies" in wich he states;
Original text by MJK
Qts -- I use a Qts value of 0.35 to distinguish between high and low Qts. You might have another definition. Drivers with a high Qts perform better than driver with low Qts in a quarter wave design. On the other hand, the lower Qts driver seems to require less volume, thereby resulting in a smaller enclosure. Low Qts drivers have a roll off that starts earlier than high Qts drivers, and drivers with a moderate or high Qts will often result in the best low end performance. But this is also a matter of taste and preferences. "Good sound" is defined by you only. The output from the opening is broader with high Qts drivers, compared to low Qts drivers that have a narrower output from the opening. Drivers with a Qts lower than 0.30 seem to be difficult to control in a TL.
also in this text it says;
choose a speaker/subwoofer with a Qts between 0.4 – 0.6, and an fs of reasonable depth.
Is there such a thing as a Qtc for transmissionlines as it is with sealed cabinets ?
Empee
Empee
Old 5th January 2009, 10:53 PM   #7
GM is offline GM  United States
GM's Avatar
Cheers !
Empee
TLs work extremely well with high Q drivers, yielding a lower f3 for a given Fp, but when you have both a high Q and high Vas they require a lot of Vb. Indeed, my default alignment for this high a Q driver is a max flat impedance TL (38.46 Hz Fp) which weighs in at a plump 292 L, though it does have enough more gain to probably not need any BSC if otherwise required and is much better damped than a 181 L MLTL/whatever. Cutting the Vb in half to 146 L raises F3 from 40 to 50 Hz, so no joy there unless it's an acceptable trade-off.
Bottom line, for a given Qts, F3, the lower Vas is, the smaller the TL, etc., Vb is, ditto Vas Vs Qts, though F3 rises at a rapid rate as Vb shrinks.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 5th January 2009, 11:15 PM   #8
GM's Avatar
Other than the max flat impedance I referenced, I don't recall anything specific, though you can match a TL's roll off slope to known Qtc values down to where it finally rolls off at a vented alignment's 4th order. IOW, If I tune your driver to Fs with an acoustically tiny CSA = Sd and stuff it heavily it will theoretically have a critically damped 0.5 Qtc down to Fs where it will start transitioning to 4th order somewhere below 10 Hz along with a nominally flat acoustic and impedance phase. This is 'ideal' compression horn performance, i.e. this is as good as it gets as far as it goes. The trade-off is an unacceptably high ~100 Hz F3 due to its tiny acoustic size plus stuffing being used to mass load (damp) the driver into a much lower effective Fs, Qts.
GM
Old 6th January 2009, 07:20 AM   #9
OK , have it your way, l was thinking more the classic tl ie; imf, tdl and pro 9 tl etc, cant say l've paid any attention to MJK's work along these lines[ no pun intended] perhaps he might chip in as l know he frequents DIY AUDIO from time to time......... or else download his design program and start with a fresh sheet of paper rather than try and shoehorn your diver into an existg enclosure design'
cheers T.C,
Old 6th January 2009, 07:45 AM   #10
Empee's Avatar
Hey T.C. & G.M. !
Thank you very much for your input, and no, I'm not trying to shoehorn my driver into something that won't work. That's the whole reaseon for me asking your knowledge !
As G.M. stated, - and G.M.; thank you very much for that ! - it's the high Vas that does it (or doesn't do it, actually)
I see now a classic TL won't work, and thinking WAF, the max-flat variation won't either, so I still don't know what to do with this
driver.
However, I still do not understand how this thing could have worked so well in the original 80 ltr. closed cabinet Philips orginally put this driver in.
check this speakercabinet
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.12328 seconds (81.96% PHP - 18.04% MySQL) with 11 queries
