Small 8" HElP - diyAudio
Old 10th April 2003, 06:53 AM   #1
jleaman is offline jleaman  Belgium
Banned
Send a message via AIM to jleaman
Default Small 8" HElP
can any one help me with building a box with these paramiters. They are 8" im thinking about buying 3 more and useing 2 per box. But for now i would like to have a ported box NOT sealed. i have it in a box now but is not the recomended one. can any one help me get the right size ported..
www.bumperspeakers.com
Serie X
Model 848 X
Diameter size in inches 8
Diameter size in centimeters 20.32
Z - Nominal Impedance in Ohms 4
Fs = Free air resonance frequesncy in Hz 62.5
Qts = Total Q Factor of driver 0.48
Vas = Equivalent acoustic volume in cubic feet 0.3
Vas = Equivalent acoustic volume in liters 8.46
Xmax = peak linear displacement of cone in inches 0.17
Xmax = peak linear displacement of cone in mm 4.32
Pe = Max power in watts 350
Ref = Driver's SPL 1W at 1m in dB 88.5
SPL = The half-space ref Efficiency 88.3
Voice Coil Diameter in inches 2
Mounting Depth in inches 3.5
Sd = Piston Area in sq m 0.018
BL = T*M Flux Density, Length Product 10.61
no = The half-space ref effciency 0.0001
Cms = Mechanical suspen Compliance 176.482
Mms = Mech mass of cone & free air load 36.707
Qms = Mechanical Q factor of driver 7.225
Qes = Electrical Q factor of driver 0.4609
Revc = DC Voice coil resistance in Ohms 3.6
Zmax = imped At top of resonance curve in Ohms 60.03
Fo = Free air resonance frequency in Hz 62.5
Magnet weight (oz) 48
Magnet weight (kg) 1.6879
Frequency response range tested from 20-2000 Hz 20-6200
Old 10th April 2003, 05:02 PM   #2
Banned
I would really like some help as i have no speaker programs for mac..
Old 11th April 2003, 01:10 AM   #3
frugal-phile(tm)
planet10's Avatar
I'll run em when i get a spare moment.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 11th April 2003, 06:31 AM   #4
navin is offline navin  India
navin's Avatar
Send a message via MSN to navin Send a message via Yahoo to navin
why ported. Qts 0.48. try TL. better still try push-push TL :-)
...still looking for the holy grail.
Old 11th April 2003, 07:28 AM   #5
frugal-phile(tm)
planet10's Avatar
Jeez... you sound like me Kool
dave
Old 11th April 2003, 07:52 AM   #6
Banned
because i have it ported now in a crap BOX actualy it is in a kenwood box with amp it is a tube thingy. IT POUNDS with out distorting and botteming out. I have always like ported.
Old 11th April 2003, 07:59 AM   #7
Banned
1
Old 11th April 2003, 08:00 AM   #8
Banned
And i Power it with my N-channel witch WORKS WELL. it is nice. I have never seen a 8" do what i can do to this one.
Old 11th April 2003, 08:02 AM   #9
Banned
And this is what the box looks like. It is Totaly not ment for a hi powered Sub.
Old 12th April 2003, 07:31 AM   #10
frugal-phile(tm)
planet10's Avatar
Not particularily suited to a reflex box.
0.53 ft^3 tuned to 50 hz (3" port, 12.1" long) gives a fairly flat FR but with a huge group delay.
Anything else with reasonably flat FR has equally ugly group delay.
dave
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 10 5th February 2015 11:50 PM
Need your opinion, how small gain can I use with LM3886 (how close to "flat amp")? danielwritesbac Chip Amps 20 30th November 2008 01:27 AM
looking for a small 2" or 3" driver with poor bass response space-cake Full Range 3 27th December 2007 02:16 AM
Thiele-Small R_ms (mechanical losses) vs. "precise" sound? capslock Multi-Way 7 16th September 2002 10:32 AM
Copyright 1999-2017 diyAudio
