Old 2nd January 2009, 11:58 PM   #1
Default Input on 5.1 diy setup, budget friendly *n00b*
It was recommended that I join up here and ask exactly what I am looking for and see what the experts think I am completely new to home audio and am looking to build my own speakers. I don't want to get into home audio as a hobby so I am just looking to build something and be happy with it, hah. This will be in a living room (11x17) for general audio purposes. Not looking to build a theater room here. Most the time watch tv with the tv speakers and receiver off. I was thinking of only using a sub when I want the extra bass for either music or movies. So I don't know if that means I should go with 3 way mains or 2 way will be sufficient. I don't need it to sound the best just decent with the ability to get decently loud if I ever need to. I was thinking about doing it in stages like building the mains first, then center and rears later if possible. The projects I had in mind were PE Tritrix, Dr. K's MTM, Zaph's BA MTM, or this RS150 MTM. I'm liking the BA MTM or the RS150 more due to the lower cost. So which of these (or other) would you recommend? Can I build just towers/mains for now then do the rest later? Any input is appreciated. Thanks
Jason
Old 3rd January 2009, 03:34 PM   #2
y8s is offline y8s  United States
y8s's Avatar
Send a message via AIM to y8s Send a message via MSN to y8s Send a message via Yahoo to y8s
If you want cheap and easy, build the B3S single driver speaker. Then build four more. Then build a sub. They should be plenty loud as long as you dont expect to overcome more than 50 people in your 11x17 room.
Old 3rd January 2009, 04:17 PM   #3
JRace is offline JRace  Canada
Hi Jason,
Whats your budget?
I would look at these:
http://www.creativesound.ca/details.php?model=MT27KITA
Full range bookshelf speaker kit using the Mark Audio Alpair 5 aluminum wide range "tweeter" and the CSS SDX7 woofer. Includes CNC cut baffle, magnetic grill, crossover parts, plans, etc. to build the rest of the speaker. You will have to source and cut materials for the rest of the enclosure to finish this kit.
$229 per speaker. / $458 pair
http://www.creativesound.ca/details....el=SUBSD12KITA
This Kit includes all hard parts necessary to build a Sub SD12. It includes an O audio 500W Bash amplifier, a CSS SD12 Subwoofer, a CNC machined baffle, and amplifier panel to mount the woofer, and amp. It aslo includes floor spikes, and screws necessary to mount the amplifier and woofer.
$499
I would build at lease the Front LT/RT and sub.
These are cdn prices from a lower mainland company.
Old 3rd January 2009, 06:50 PM   #4
Budget is hard for me to say at this time. I look at this way. If someone recommends something that is more than I want to spend, I will save to get those if I like them. I want to build all my own cabinets. From lots of reading I like the look and cost of the nat p's that I saw over at htguide. I want floor standing mains and using a 3" port since I have a couple of those already. I'm hoping to source most/all parts from PE if possible.
Thanks Jrace for the info, I've bought from Bob before once. At this time I don't have a receiver yet either (thinking onkyo 705 :S). I will be building a sub either use a 12" infinity reference, or a jl 12w6v2. The bash 500 will be the plate amp I'm after if I don't start with a receiver that will power one.
Old 3rd January 2009, 06:50 PM   #5
jrmxj is offline jrmxj  United States
Jason, i recommend the tritrix they have alot going for them,
1. about 180 a pair for drivers and xo.
2. easy 8 ohm load.
3. easy to build xo.
4. can be built sealed, vented or tl.
5. they sound very good for the money.
there is a matching tm that you can use for sourounds
Old 3rd January 2009, 07:25 PM   #6
frugal-phile(tm)
planet10's Avatar
If you go that wat, for a bit more budget the FF85K can be put into a small box.
If you have the budget i would consider the CSS FR125 as a really good all-rounder that works REALLY well with HT receivers. It does -- IMO -- work best in a 5-10 liter enclosure (sealed or aperiodic). Hard to make that into a floorstander, and it won't use your ports up.
Add a sub and away you go (also from Bob, a pr of SDX10 or a single SD12.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 3rd January 2009, 10:44 PM   #7
blue934 is offline blue934  Canada
[ I'm hoping to source most/all parts from PE if possible.
don't forget solen.ca. they carry a great selection and are in Canada - less shipping hassles.
where abouts in b.c. are you located?
blue934
Old 3rd January 2009, 10:57 PM   #8
Quote-CSS FR125 as a really good all-rounder that works REALLY well with HT receivers. It does -- IMO -- work best in a 5-10 liter enclosure (sealed or aperiodic).-Quote
Planet10 do you have any examples of this unit? 5L sealed x5 +sub would make fo a very WAF. possible fr graph -f3, f10?
what is the FF85K?
blue934
Old 4th January 2009, 01:18 AM   #9
2. easy 8 ohm load.
Where can I find the info to look over the other box designs? Also info on the surrounds? Thanks
Old 4th January 2009, 01:18 AM   #10
The Island. Their site seems to be down right now, haven't been there before. Post moderation ftl ;(
DIY DAC with input switchingon a budget? mikesnowdon Digital Line Level 46 12th May 2011 07:34 AM
High quality DSP crossover setup on a budget? Thunau Multi-Way 2 2nd November 2007 10:55 AM
Designs? L18 + RS28/NC D25 For Budget Audiophile setup? demon2091tb Multi-Way 5 27th November 2005 08:05 PM
n00b looking for a budget cartridge mrunexpected Analogue Source 6 14th August 2005 06:25 AM
would like some input on a setup ChemMan Multi-Way 4 9th December 2003 05:14 PM
Page generated in 0.12560 seconds (75.83% PHP - 24.17% MySQL) with 10 queries
