I was just wondering if they were worth the giant $$$.
I have never heard any and am dead curious about the SQ....not that I would ever consider dropping 6K on a set a tweeters! -JH |
#2 |
Well, other materials are currently being used to achieve piston-like behaviour at that diameter to well above 20khz. So, diamond units aren't doing anything that isn't already being done.
To truly exploit the stiffness and low mass of diamond, a much larger diaphragm should be fashioned. That way, a wider frequency range could be covered without break-up. But that, of course, would REALLY be expensive.
NV&H |
#3 |
instead of diamond, you can use zirconium which is almost as stiff. with such materials you can have 1.5" dome tweeters that will act pistonic to well past 20kHz.
#4 | |
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#5 | |
Not nearly as hard or light as diamond. Not even close to corondum. Mohs scale: Diamond 10 Corondum 9 Zirconium 5 Mohs scale is not linear so the differences are greater than the number above indicates. And zirconium is almost twice as heavy as corondum and diamond. /Peter |
#6 | |
/Peter |
#7 | |
#8 |
Yup, ruby/corondum is what T&P/Accuton has been using since mid 90's for their drivers.
Visaton has some tweeters as well using corondum. I switched from Esotar T330D to Accuton C23 and never looked back. /Peter |
#9 |
Dont forget that its not real diamond, but rather cheap artificial stuff which I understand is more of a chemical process and not even very complicated nor expencive in any way, as far as I know...but I suppose lots of experiments does cost serious money
#10 |
When I cut glass building aquariums and stuff I don't care if the cutter is a one piece of diamond from Southafrica or some artificially manufactured stuff. If it cuts the glass I'm satisfied. Don't care if the cutter is manufactured by a fat stinking old man or a blond virgin either!
If it's a cheap process I suggest you get into the business and give B&W and Accuton a hard time. ;-) /Peter |
| Capacitors and hype! | boiss | Tubes / Valves | 117 | 6th July 2010 10:44 PM |
| Diamond Amp | TimS | Solid State | 9 | 19th January 2009 01:20 AM |
| Custom black membrane Accuton D20-6 diamond tweeters for sale - never soldered! | jb0194 | Swap Meet | 0 | 12th July 2007 07:11 AM |
| After all's been said and done... Did the Sonic Impact T-amp live up to the hype? | KT | Class D | 56 | 5th March 2006 05:53 PM |
| Advertising Hype or ???? | Co_Driver | Solid State | 1 | 1st September 2003 09:33 AM |
| Page generated in 0.14337 seconds (61.05% PHP - 38.95% MySQL) with 10 queries |
