Taking a "bite" out of a tweeter - Page 2 - diyAudio
Old 11th April 2003, 05:51 AM   #11
well...I've drawn them without the tweeter and woofer's lips overlapping, but I've didn't draw bracing either. In other words, this cabinet is not final and is open for suggestions. So please, tear it apart. This is just some thing to start from.
My goal is a moderately well damped, solid, decent looking, and simple to construct enclosure with an f3 of around 35 (which this box attains). I don't really know where to put bracing, or how to place the drivers optimally on the baffle. What I have should be fine, but if anyone has some fun tweeks, let me know.
Thanks!
-andy
Old 12th April 2003, 03:59 AM   #12
For the cleanest cut, you can use your router. Flush mount the tweeter, tape it up, and then cut the rabbet for the woofer. A carbide bit will cut right through plastic or aluminum. Depending on the tweeter, you may need a shim/spacer to hold the router base high enough that it doesn't hit the dome. Alternatively, to avoid damaging the tweeter, you may be able to remove the faceplate and mount it temporarily for the cut.
Old 12th April 2003, 04:31 AM   #13
TheoM is offline TheoM  United States
Default Mounting for time alignment or polar response
Either way this begins to look like a coax. You get a very organized bubble (and time alignment). Kinda cool. It might be worth the compromize to mount the tweeter on a thin steel bar as though it were a coax - in front of the center of the woofer. Obviously you'd get some reflections and lose some time alignment because the tweet would be in a different plane.
I mostly seen polar patterns are needed to engineer coverage - usually are not a big problem in home installations. Coax designs are used for time alignment, even coverage, and to save space, I think.
Old 13th April 2003, 04:25 PM   #14
I like catapult's idea, i was thinking of something along those lines. After some consideration, I may simply mount the tweeter in the fasion that I have shown above. It would be simpler, and I can't really imagine 1/2" more space between the woofer and tweeter making all that much of a sonic difference. Am I wrong?
However, I do need some advice on the box, so I'm going to start a new thread for that.
Thanks,
-andy
suspending a small tweeter in front of woofer for "coaxial" effect? bikehorn Multi-Way 10 5th February 2015 10:50 PM
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 06:42 PM
Round radiating tweeter, aka "Enterprise 1" tweeter! tubee Multi-Way 39 13th May 2007 09:03 AM
6.5" silver flute with 1 1/8" dayton silk dome tweeter jadenlinkletter Multi-Way 10 28th February 2006 07:20 AM
Copyright 1999-2017 diyAudio
