I know that I can calculate the length of a port for a particular box volume, frequency and port area, using this formula: ![]() - where L(ength of the port) and D(iameter of the port) are in metres, V(olume of the enclosure) is in litres and F(requency of port resonance) is in Hertz. But I'm a bit lost in how to reverse the process (or the formula). You see, I'm looking to work out the port diameter to use when I already know the length of the port. Why? you ask. I was just trying to see how easy it would be to use a hole cut in a box as a port - so the length might be 1 inch (25mm) or half an inch (12.5mm). Or I might have a circular 'cover' on the and of a pipe speaker and want to know what height to make the gap so that it resonates at the right frequency. Just for interest at the moment...
Jont. "It is impossible to build a fool proof system; because fools are so ingenious." |
#2 |
Hi Jont,
I'm too stunned and lazy to work that out - I use Unibox for calculating such things. Chances are a hole will not suffice as an effective port for most applications. In order to reduce length, diameter needs to be reduced as well. This can lead to "port noise" if the diameter is too small. |
#3 | |
Syd |
#4 |
I'm currently fiddling around on Excel, trying various sizes until it fits. What I was looking at (that brought this up) was thinking of how to make surrounds WAF positive.
I've seen these bowls from ikea and thought that if I mounted a F/R driver in the 'base' and then fitted them to a flat base and hung that on the wall then it might work. After MJL's input, may with a little 'brim' on the edge, then they might work (as this would increase the length of the 'port'). Like this (primitive) sketch:
#5 |
Jon they're surrounds, make em sealed and loose the ulcerating addition and subtraction and all that math.
cool idea tho
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#6 |
How would you solve
a*x^2+b*x+c=0 where: x=D c=-L b=-0.8 a=2e6/(Vb*Fb^2) doesn't that look like a quadratic root question? Isn't there some sort of formula that we were supposed to memorize when we were ~14-15 years old, something like: http://en.wikipedia.org/wiki/Quadratic_equation note that there are two solutions, but one of them will be easy enough to throw out if you think on it a bit.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#7 |
WinISD Beta is a good, fast program to figure that out
(*nix users - it runs flawless in WinE, at least in Ubuntu Cheers! |
#8 |
If you use the Helmholtz formula..
f = k(a/lv)^.5, k=c/(2pi) for any given f and v the ratio a/l is constant rcw. |
#9 | |
I might have to try it out anyway - I can always just tighten the bolts a little more and it'll become sealed...
#10 | |
I don't use small ports for that reason. Syd |
| Bass Reflex port for Usher 701 kit | nippontiger | Multi-Way | 7 | 16th September 2008 03:11 PM |
| Q-factor of bass reflex port | SSassen | Multi-Way | 6 | 26th March 2005 08:26 PM |
| Page generated in 0.11104 seconds (77.18% PHP - 22.82% MySQL) with 11 queries |
