Dickason in his LOUDSPEAKER COOKBOOK says that Qts of a driver can be lowered by stretching porous fabric over the rear of the basket of the driver.
Does anyone know what type of fabric can be used, how to attach it to the basket of the driver and to what extent Qts can be lowered by doing this? -Pete |
#2 |
Since the vast majority of Q is electro-mechanical lower the mechanical Q does not have much effect. Maybe 15%. Many layers of open fabric would work best.
#3 |
Yes, the fabric basically acting as a mechanical brake, changing Qms, and Qts. I think this is something that would be hard to estimate, so measuring would be the only way to know exactly how to have changed the parameters.
If the driver is a dual voice coil, you can use only one voice coil, and use the other voice coil terminals as a magnetic brake, instead of a mechanical brake as with essentially smothering the back of the driver. A resistor can be installed across the terminals of the unused voice coil to adjust the Qts. However, using only one voice coil on a dual voice coil loudspeaker I would expect to cause a decrease in sensitivity (due to decreased BL) and power handling.
The power of Science compels you! |
#4 | |
This approach is very similar: Favorite Threads and Posts in "Subwoofers" http://www.diyaudio.com/forums/showt...56#post1459356 b |
#5 |
Thanks to all for your replies, especially those from Earl Geddes and Bjorno.
I did search the site for pre-existing advice on this topic, but apparently not zealously enough. -Pete |
| lowering caps ESR | pjpoes | Power Supplies | 5 | 10th May 2007 02:28 PM |
| Lowering HT | waner | Tubes / Valves | 7 | 29th May 2006 10:31 AM |
| lowering the voltage | Lowjacker | Power Supplies | 7 | 11th March 2006 09:11 AM |
| Help needed lowering B+ for DIY amp | Hankster | Tubes / Valves | 6 | 11th February 2006 09:23 PM |
| Lowering 5.4V to 5.0V | Ralph | Parts | 4 | 20th January 2003 12:37 PM |
| Page generated in 0.08012 seconds (69.30% PHP - 30.70% MySQL) with 10 queries |
