Old 30th December 2008, 11:36 PM   #1
bng is offline bng
Default 4ohms and 8ohms speaker drivers
I still new to this speaker building. I have finish and built my 3-way design speakers and now I want to start building another one. This time, I want to built something bigger.
Right now, I have these speaker drivers in 8ohms.
pair Dyaudio T330D
pair ScanSpeak 18W/8531G00 mid-woofer
four ScanSpeak 22W/8857 woofers
I want to add in a ScanSpeak 12m/4631G midrange driver but it is a 4ohms driver.
The speakers will be driving my a Krell FPB-300c amplifer.
Since all my drivers are 8ohms and now i am adding a 4ohms driver in the crossdriver.
Will the speakers works and will the amplifer still be able to drive all the speakers without something going wrong or blow up?
Old 31st December 2008, 12:36 AM   #2
Speakerholic
Cal Weldon's Avatar
Hi Brian,
It might not blow anything up but you can't just swap drivers around. Unless the new mid happens to be about 3dB more efficient than the existing and you add 4 ohm series resistance, but even that isn't all there is to it. If the other drivers are matched and properly XO'd then I would think about a new project rather than substituting. Is this your project from '02?
http://www.diyaudio.com/forums/showt...6114#post26114
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 31st December 2008, 12:48 AM   #3
bng is offline bng
great info. Thanks Weldon. I will use another alternative midrange driver with a 8ohms rating.
btw: I did not able to get a chance to find the dynaudio woofers at that time. Instead I used a scan speak woofers. That was my first speaker project date back in 2002. Took me almost a year to built the speaker.
now i am doing a second speakers and this one might just as well take me about that time or lesser given the experience from the first.
100w into 4ohms? Powertimes_2 Solid State 4 1st December 2008 11:50 PM
Have to mod K-502 to 4Ohms from 8 udailey Tubes / Valves 1 13th March 2008 03:27 AM
LM3886GC, Does it prefer 4ohms or 8ohms? henkel Chip Amps 14 22nd November 2006 04:08 PM
WTB: Vifa P17 4ohms AR2 Swap Meet 1 13th October 2006 03:53 PM
Lowpass , two 8ohms speaker Guss Multi-Way 11 29th June 2003 11:28 AM
Page generated in 0.07751 seconds (68.49% PHP - 31.51% MySQL) with 10 queries
