Old 30th December 2008, 09:50 PM   #1
Web Wolf's Avatar
Default My SCAN SPEAK Tweeters don't work !!!!
Hi everybody, I'd like to post my problem with my SCAN-SPEAK tweeters D2904.
In fact, more than one year ago I bought these tweeters but they had the membrane a bit defective so I asked to SCAN SPEAK to repar them. After 3 months they substituted them and I saw the SPL and I thought it was very good. But now, I measured impedance curve of both speakers and I saw that one speaker have a perfect impedance but the impedance of the other speaker is full of garbage !!!
I repeated the measurements but it was the same result !!!
Perhaps there was a problem during substitution of the membrane but the real problem is that I can't use warranty now
What could I do ? Should I disassemble the tweeter ? How could I do ?
(please excuse my english)
HELP MEEEEEEEEEEEEEEEEEEEEEEEEEE!!!!!!!!!!!!!!!!!!!!!
Old 30th December 2008, 10:27 PM   #2
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
You could try to open the tweeter and try to line up to see if the voice coil is vibrating free.
May be there is some dirt between the voice coil and pole plate.
( (( KUGELWELLE )) )
recent projects :OB-mk1 /fatboy / monitor-xl / Horn-AM / dappolito / td124-mk1-rb301 / Hybrid-pse / Vfet
Old 31st December 2008, 09:08 AM   #3
Web Wolf's Avatar
I could try.
I thought: may the tweeter be damaged by measurements with MLS signal ? I think it could be strange because we are speaking about few seconds and two ore three measurements...
Is there a way to post a photo here ?
Where could I put my photos ?
Old 31st December 2008, 10:50 AM   #4
Helmuth's Avatar
With a test signal of 1w the speaker can't damage but with to low frequencies I don't know.
And the x-max the tweeter makes I guess.
Old 31st December 2008, 10:58 AM   #5
Web Wolf's Avatar
Consider we are speaking about few seconds of MLS signal !
I didn't never use a condenser because it could change phase response or not ?
Old 31st December 2008, 11:05 AM   #6
you've blown it, it is not warranty.
Protect your tweeters by always feeding through a series capacitor to block DC and attenuate low frequencies.
regards Andrew T.
Old 31st December 2008, 11:18 AM   #7
Web Wolf's Avatar
Only with few seconds of MLS signal ???
The membrane are perfect !!
Old 31st December 2008, 11:20 AM   #8
I have never taken a tweeter apart, but I suspect the Voice Coil looks like the wire is little bigger than hair.
regards Andrew T.
Old 31st December 2008, 11:37 AM   #9
Web Wolf's Avatar
I've a lot of old tweeters that were measured and played in every conditions but the impedance of them all are always perfect.
This tweeter never played without a condenser, only during two or three measurements.
It seems a little strange to have damaged a tweeter in this way.
Here are a photo of the impedance measured
Old 31st December 2008, 11:39 AM   #10
Web Wolf's Avatar
And here is the image of the other tweeter
Now I've measured the same tweeter (the "damaged" one) with a very low level and the impedance became better, but with two resonance points.
NIB Scan Speak AirCirc Tweeters sbrtoy Swap Meet 1 13th May 2009 04:28 PM
FS Scan Speak Tweeters & Midranges bigLG Swap Meet 8 8th February 2009 01:37 AM
WTB: Scan-Speak D2905 tweeters (UK) irb Swap Meet 0 14th March 2007 09:01 PM
WTB: Scan speak midwoofers and tweeters gaminn Swap Meet 0 28th January 2007 01:42 PM
WTB: Scan Speak 9500 tweeters dmitriy167 Swap Meet 2 19th September 2006 02:07 PM
Page generated in 0.10143 seconds (76.20% PHP - 23.80% MySQL) with 11 queries
