Old 8th April 2003, 11:59 PM   #1
G is offline G  United States
G's Avatar
Question Slotted vent calculation?
Hi all,
I am building a pair of bass reflex speakers and I need a little help. The design in the pdf below( the bass reflex enclosure at the bottom right) uses a round port. I would like to use a slotted port. Can anyone be so kind as to give me the formula for calculating the port dimensions for a slotted port? Any help is appreciated. Thanks.
G
http://www.fostex.co.jp/int/pages/pr.../206e_encl.pdf
Gavin
Old 9th April 2003, 03:10 AM   #2
mikee12345's Avatar
www.diysubwoofers.org >ported box xls file
www.linearteam.dk >winisd,and port calculator.
www.jlaudio.com >tutorials
Old 9th April 2003, 06:16 PM   #3
OMNIFEX is offline OMNIFEX  Jamaica
OMNIFEX's Avatar
Please keep in mind Slotted, Shelfed, ducted, vents
take up more of the internal chamber, than a circular
vent.
Pending on how over, or, under you're scaling the
optimum enclousure, this may play a factor.
Best Regards,
OMNIFEX
Old 9th April 2003, 06:38 PM   #4
G's Avatar
I had planned on using this duct:
http://www.psp-inc.com/images/4%20x%...0seperated.jpg
In the instructions on how to calculate the length they say that it should be positioned at least one port diameter away from any adjacent walls of the enclosure. Why? The duct is from Precision Sound Products. Using this would certainly make things easier and look better but my enclosure is only about 11" wide which rules out using the 4" duct.
G
Gavin
Old 9th April 2003, 08:02 PM   #5
Hello,
You can use a slot port in the place of a round port. The length will remain the same.
To calculate the port size in square inches you need to take the round port radius and multiply it by 2, then multiply by 3.14, this will give you the square inches of the port.
For example a 6inch round port has a radius of 3". Multiply 3 x 3 to get 9 and then by 3.14 for approx 28" square.
To calculate your slot port of same size simply use length x width until you come up with the shape you want. A 4" x 7" would work for the 6" round port above.
As a rule your inner port end should be no closer to a wall than 1/3rd the port diameter.
That's all I know.
KevinLee
Old 9th April 2003, 09:22 PM   #6
G's Avatar
Thank you Kevin. That helps a lot.
G
Gavin
Old 9th April 2003, 11:38 PM   #7
download winisd, it helps alot, and you can see graphically what changes in port size make.
-andy
Old 10th April 2003, 01:00 AM   #8
According to this site slot ports are much shorter than rectangular ports to achieve a desired tuning freq. Seems that because you're using a wall of the enclosure as part of the port, the slot port gets shorter. Hard to believe it's this much, tho I've never tested them.
Pete
Old 10th April 2003, 01:51 AM   #9
Pete,
you are correct! Slot ports are different than square or rectangle ports.
In my post above when I said slot port, I should have said rectangle port.
KevinLee
Old 10th April 2003, 01:59 AM   #10
mikee12345's Avatar
yep having the duct against the wall of the box causes it to be 1/2 the distance across the duct,shorter
www.jlaudio.com >tutorials >>ports an ducts
to vent or not to vent ? Bigun Full Range 13 23rd January 2009 09:13 PM
FR125 MLTL slotted port question valleyman Full Range 7 17th September 2008 03:47 PM
Pioneer + Piezo in a 3 cu ft slotted box ajh Full Range 3 25th September 2007 03:07 PM
Fulmer's k-slotted pipe for 15" freddi Multi-Way 0 23rd April 2007 02:46 PM
Karlson-slotted pipes PeteMcK Multi-Way 6 23rd June 2004 09:10 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
