Visions of PLLXO's danced in his head....
Old 23rd December 2008, 09:42 PM   #1
scottw is offline scottw  United States
Default Visions of PLLXO's danced in his head....
Familiar story, open baffle with 8 inch wide range, passing the lows (< 200Hz but yet to be determined) off to a 15 inch prosound driver. Just became bi-amp capable and going to try a 2nd order PLLXO for low pass.
Have found the T-line site helpful:
http://www.t-linespeakers.org/tech/f...ssiveHLxo.html
but little else available on line or in forums. And I still have some questions:
Is a line level 2nd order (R's and C's, no L's) still going to cause a 180 degree phase change? I probably should know this.
2nd order PLLXO is a cascade of two 1st order while maintaining an impedance ratio (1:10) of the components (more or less with exceptions). What is the result if you reduce this ratio to 1:5 or 1:2?
Does it effect the slope of the xo or does it effect the frequency extremes-i.e., roll off the highs or lows?
Thanks,
Scott
"The Adobe Updater must update itself before it can check for updates. Would you like to update the Adobe Updater now?"
-Adobe Updater
Old 23rd December 2008, 10:05 PM   #2
Ron E is offline Ron E  United States
Ron E's Avatar
Default Re: Visions of PLLXO's danced in his head....
Yes.
Model it with LTSpice and see the answers to both questions.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. óAldous Huxley
Old 23rd December 2008, 11:18 PM   #3
I'm afraid the only "spice" I use is in the kitchen.
But I guess it's getting to the point where I need to download it and learn to use it.
Scott
-Adobe Updater
Old 24th December 2008, 01:24 AM   #4
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
If you reduce the ratio, the 2nd section loads down the 1st section, so the XO starts shifting around. If you diyed your amps or are willing to go into them, inserting 2 1st order filters will get you more consistency.
The passive filters create the same phase rotation as any analog filter would.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th December 2008, 02:38 AM   #5
Pano is offline Pano  United States
Pano's Avatar
Hey Scott. Ditto what was said above.
Plus as you change either source impedance or load impedance things will shift a bit. As they get closer to each other the overall attenuation will rise.
Do you know what your source impendance and load impedance are? Or can you give us an idea of what you are using?
Take the Speaker Voltage Test!
Old 24th December 2008, 08:57 AM   #6
Thanks for the replies.
Hey Dave, do you mean put one 1st order in front of the amp and another in between stages in the amp? Might be tough to do cause I plan to try a number of xo points till I find what works. And this may be quasi-temporary.
Plus as you change either source impedance or load impedance things will shift a bit....Do you know what your source impendance and load impedance are? Or can you give us an idea of what you are using?
Hmmm...Source is a TVC (S&B Mkiii) and the output impedance does vary; but in the range I listen it will usually be from a few Ohms to 100 Ohms (measured at 1kHz).
The amp for the lows is an integrated sand amp with around 50K input impedance-actually DCR stays at 55k till the volume gets to 75% then it tapers to 40K at full volume. It drives the 15's now with a speaker level 2nd order with this amps volume control at about 12 o'clock. So I've got room for a little insertion loss.
My original thinking is if I could cheat on the 1:10 ratio and increase the impedance it may help prevent loading the TVC too much. But it may not matter that much, I may just try it as recommended and see how it does.
Scott
-Adobe Updater
Old 24th December 2008, 05:38 PM   #7
frugal-phile(tm)
planet10's Avatar
exactly. You won't get the droop of 2 cascaded passive RC.
Give it a try. If the highs go away you don't have enuff grunt.
It is only the HF amp that usually has a problem.
dave
Old 24th December 2008, 06:03 PM   #8
Pano's Avatar
Yeah, that TVC gives you a nice low output impedance.
You shuld have no troubles with that setup. I thought you might be driving it out of a passive pot preamp or something.
Dave, what do you think is a good value for his R1 in the PLLXO?
Old 25th December 2008, 12:42 AM   #9
frugal-phile(tm)
planet10's Avatar
Originally posted by panomaniac what do you think is a good value for his R1 in the PLLXO?
The filter would be happiest if he does 0.5 uF + 5k
dave
Old 25th December 2008, 07:55 AM   #10
Thanks guys.
I'm diggin' through my spare parts bin to see what caps I can match up for the job.
Scott
-Adobe Updater
Visions of PLLXO's danced in his head....Hide this!Advertise here!
Visions of Holey-Basket Corals pjanda1 Full Range 15 22nd July 2010 03:24 AM
Calculate PLLXO audiobomber Multi-Way 5 22nd August 2007 06:34 PM
Using phono input with PLLXO mashaffer Subwoofers 0 14th August 2007 12:36 AM
PLLXO high pass Soulwax Multi-Way 8 6th May 2005 01:40 AM
Visions in audio - recomended compononts FaZ72 Analogue Source 0 21st May 2004 05:44 PM
Copyright ©1999-2017 diyAudio
