Hello
I have 4 Altec 421-8H baskets with 416-8B Cones I know the TS parameters of the original 416-8B speakers with its Flux Density of 1.1 Tesla Now, new flux density with 421-8H basket and 416-8B cone is 1.44 Tesla Is it possible to calculate new TS parameters since we know original parameters and original and new flux density ? Is New Bl = (1.44/1.1) * Bl(416) ? Thanks Bruno |
#2 |
In simplified theory, yes, that would be correct. In reality it would be correct if the flux distribution through the gap region was the same as for the 416-8B (so the ratio of flux density was the same at all points). If the top plate thicknesses are different between the speakers, then this will probably not be the same. If you build the speakers, just measure the parameters to find out what BL really is.
#3 |
You will roughly cut Qes in half, which will double efficiency.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#4 |
Hi
Thanks for your answers Yes, the best way is to measure new parameters, but I was wondering: Do Cms and Rms depend only of mechanical characteristics of the cone? In that case: Fs should be the same (1/(2*PI*SQR(Cms*Mms)) Also Qms (2*PI*Fs*Mms/Rms) Also Vas (Rho*C²*Sd²*Cms ) And Qes should be (1.44/1.1)² smaller, is that what you mean Ron E ? If Cms and Rms do not change, measuring new Bl instead of estimating it (1.44/1.1) should be enough ? Rgds |
#5 | |
Rms should not change much unless former is conductive. Cms is just springiness, nothing to do with motor. Measuring Qes, Qms is easier than Rms or Bl.
| TS parameters when changing Flux Density | f4bok | Pass Labs | 2 | 23rd December 2008 02:46 PM |
| High density Fibreboard UK Supplier? | calvert73 | Subwoofers | 1 | 17th December 2008 10:57 PM |
| 26 pin High Density D Sub Plugs and Sockets | fmak | Parts | 3 | 4th August 2006 06:33 PM |
| Core saturation and flux density calculations | machinehead | Power Supplies | 8 | 17th January 2006 07:45 PM |
| changing t/s parameters | airman | Multi-Way | 17 | 10th January 2006 08:47 PM |
| Page generated in 0.09423 seconds (75.47% PHP - 24.53% MySQL) with 10 queries |
