I’m sure this is just greasy kid’s stuff to you guys but could someone please explain to me (or point me at an explanation of) how impedance matching works when using crossovers? I’m OK on a 2 speaker level, but what would the options be if I wanted to drive two 8 ohm speakers and one 8 ohm tweeter using a crossover? Can the crossover be designed to cope with the unequal HF and LF impedances and still give me the desired 4 ohm overall impedance?
labougie |
#2 |
Hey "Candle" - don't sweat the 4 ohm 8 ohm thing.
If the low section is 4 ohms, just design the crossover for it. Ditto the high and mid sections. You need to design that part of the crossover for the real impedance of THAT section. That's all. Hope that makes sense.....
Take the Speaker Voltage Test! |
#3 |
Final impedance to be flat as possible would be my recommendation.
Hear the real thing! |
#4 |
Great - just what I hoped to hear - thanks.
labougie |
| Impedance Matching | maxzimum | Solid State | 2 | 9th April 2009 02:03 PM |
| Impedance matching | Triod lover | Tubes / Valves | 2 | 12th January 2007 09:59 AM |
| Impedance matching | nogoodboyo | Tubes / Valves | 3 | 17th March 2006 11:55 PM |
| Need help understanding transformer impedance ratios and impedance matching | percy | Tubes / Valves | 5 | 28th February 2005 08:35 PM |
| impedance matching | fragman56 | Tubes / Valves | 17 | 20th March 2003 02:38 PM |
| Page generated in 0.07593 seconds (69.37% PHP - 30.63% MySQL) with 10 queries |
