Tad 4001 , ET-703 integration
Old 18th December 2008, 05:12 PM   #1
limono is offline limono  United States
Default Tad 4001 , ET-703 integration
Does anybody have an experience with adding ET 703 supertweeter to TAD 4001 mid? Tad 4001 is mounted on 350 hz tractrix. Crossover points,slopes ,padding, parts used etc.
TIA and regards
L
Old 22nd December 2008, 10:29 AM   #2
heifisch is offline heifisch  Germany
Default crossover
I am using a 4001 and a 703. I tried different crossover frequencies. I started at 7000 Hz and now ended up at 5000 Hz.
I use a Neville-Thiele filter 1st order.
This is a digital filter and has a steep slope. Crossing at 5000HZ means at 2700Hz it has already -40dB. I am using "acourate" a software for making crossovers for up to 5-way speakers and a room correction system is implemented in acourate as well.
I am very pleased with the result.
Have a nice xmas.
heifisch
Old 22nd December 2008, 04:22 PM   #3
Hi Heifish
I thought that you're using TD2001 for a tweeter.
I've got TD4001 , also TM 1201 and ET 703 (all used ) just recently and try to cobble it in a system.
I'd have some questions regarding TD 4001 impedance. My units have ~7 Ohm DCR . According to some it's 8 Ohm driver but others say all 16 Oms TD 4001 measure between 4-8Ohm. J.M Le Cleach posted an impedance graph and it does show that driver impedance in Horn (I think it was TH4001 ) is 16 Ohm at 700 Hz .
I do not want to go into active crossover /multi amp config. I will use K-horns for bass and from 80-100 TM1201 in hypex horn up to 700 Hz.
What was your best sounding passive crossover ?
So far ( since I didn't build midbass horn yet I'm listenning to TD4001 in 350Hz horn crossed at 700Hz to altec 15" (no supertweeter attached) It has a resolution ,detail etc . It is fairly smooth but after 1/2 hour I'm tired of it.
Are you familiar with Cessaro crossover implementation?
Best regards and Happy Holidays as well
L
Old 23rd December 2008, 01:11 PM   #4
Default 4001 703
Hi limono,
for impedance try arta. This is a nice software to measure frequency, impedance and a lot more. It has a very good manual and you can get lots of information how to build your measuring equipment and how to use it. It is not expensive and I think you can use it free, if you do not save your measurements.
If you have a mac, you can use fuzzmeasure for kind of similar things. In the fussmeasure manual is explained how to measure the impedance of a speaker.
Sorry, I have not tried passive crossover with the ET-703. I did a measurement and it goes down to 4000Hz. TAD recommend a 2nd order filter and a cutoff frequency not lower as 5000 Hz.
When I used the 2001 I had a ppassive crossover 1st order at about 4000 Hz. This was nice too, but it is not an easy setup because there are lots of frequencies both units play.
Sorry, I do not know what Cessaro is doing in their crossovers.
Best regards
heifisch
Old 25th December 2008, 05:16 PM   #5
Heifisch
I will play around with the drivers/horns and ask more questions as work progreses .Thanks for all the info
Greetings
L
Old 8th February 2010, 06:59 PM   #6
Alpinerunner is offline Alpinerunner
Hello Heifisch,
I am interested in building up a similar system like you have with a pair of TAD 4002 and ET-703.Unfortunately I donīt have any experience with this driver.Sure they are the top what you can get for money but I think I will struggle with the crossover set up.
I have seen that you are from the Cologne area.I am working on a temporary job here in Cologne.My question would be if it is possible from your side to exchange some information about that or even meet up for a listening test at your place.
Thanks.
Best regards.Alpinerunner
Old 28th November 2010, 08:01 PM   #7
HP8903B is offline HP8903B
Here is the response graph of the TD-4001 and ET-703.
Perhaps these graphs might give an idea about integrating these two drivers.
Also, in the Exclusive 3401 speakers, the ET-703 is crossed at 7kHz.
Old 28th November 2010, 09:17 PM   #8
Hi alpinerunner,
sorry I did not recognize your post. If you are still in the cologne area, feel free to contact me by pm.
heifisch
Tad 4001 , ET-703 integrationHide this!Advertise here!
what is lower cutoff of tad 4001 sans horn? enochRoot Multi-Way 15 6th November 2007 10:57 AM
Sub integration JRKO Subwoofers 28 13th September 2006 09:29 AM
E-speakers 4001-1601 ref. kartsmart Multi-Way 9 9th September 2005 09:27 PM
Very strange HP Passive network for TAD 4001 TADonly Multi-Way 5 30th May 2005 01:47 AM
Usable frequency response for TAD 4001 Rocky Multi-Way 57 1st June 2004 05:20 PM
