Old 16th December 2008, 05:59 PM   #1
Default 2way Studio monitor with 10 inch woofer help
I am planning to build a pro studio monitor with the following drivers..
10 inch woofer:
http://www.tymphany.com/pl26wr09-08
Tweeter:
http://www.wavecor.com/html/tw030wa05_to_08.html
TW030WA05
I would like to know what crossover point suits best for this or do u recommend any other tweeter for this? but what about mids? can this 10 inch driver produce better mids? since its for studio monitor the user will be on near to 0 degree axis to the driver...
please give your suggestions...
Old 16th December 2008, 06:39 PM   #2
maybe i will be a bit heretical, but have you considered a BG Neo8pdr?
You can cross it lower enough (6-800Hz) and, in the "near field" you sure do not need a supertweeter. I have used it with excellent result,
a very nice planar and handle a lot of power !
That vifa 10"like low crossover point imho, no possible with a 1-1/4"
domes.
Just my 2 c.
Paolo
Old 16th December 2008, 07:22 PM   #3
can u tell me one thing... I have a midbass driver with a heavy L-pad attenuation for about 7db but I just doubt how does it affects the overall performance and stability... I need to match the mid with the 10 inch vifa..
can u pls tell me as I couldnt find a proper guidance for this..
Old 16th December 2008, 11:31 PM   #4
rcw is offline rcw  Australia
You say you want to make a studio monitor.
One of the main requirements is that it can produce large acoustic outputs with low distortion, this driver pair can do this with a crossover in the 1500Hz. region and a lower cut off around 40Hz. with a filter assisted alignment.
Ideally the tweeter would be waveguide loaded.
More details about your l padded driver are needed.
Part of the l pad resistance appears in series with the driver causing qt to increase, this can cause boom, which may or may not be a good thing according to the application.
rcw.
Old 17th December 2008, 08:52 AM   #5
Try something like this:
http://www.troelsgravesen.dk/JA8008.htm
Old 17th December 2008, 12:56 PM   #6
Rhytmdiy, you will have to padd the tweeter, not the woofer
You can expect a speaker with 81-82 dB /2,83v/anechoic with full baffle step compensation.
cheers,
Paolo
Alpine SPR-17LS mid-woofer for 2way monitor? bastek Multi-Way 4 12th August 2007 04:19 PM
Studio monitor gev Instruments and Amps 30 17th January 2006 06:53 AM
J-Low as a Studio Monitor? atticus Pass Labs 2 22nd August 2004 08:37 PM
6 to 8 inch driver for studio monitors cm961 Multi-Way 3 17th February 2004 02:40 AM
DIY studio monitor mgoedeke Multi-Way 4 22nd June 2003 02:29 AM
Page generated in 0.09426 seconds (74.69% PHP - 25.31% MySQL) with 10 queries
