Old 16th December 2008, 04:28 PM   #1
Khron is offline Khron  Romania
Send a message via AIM to Khron Send a message via MSN to Khron Send a message via Yahoo to Khron
Default DIY braided CAT5 questions
Greetings everyone...
I'm in the process of putting together a pair of bi-amped "bookshelf" speakers, and i'll be using 4-pole Speakon terminals on the amps and speakers.
I'm considering using CAT5 cable as speaker wire (cheap, reasonably low capacitance). One strand of cable for the tweeter (coloured wires = "+", whites = "-") and 2 strands for the mid-bass (same "colour-coding")
The question i have is this:
Would making a 3-way braid (like this ) have any negative effects on the signal presented to any of the two drivers (or amps)???
Old 16th December 2008, 04:48 PM   #2
...truth seeker...
Ed LaFontaine's Avatar
Location: where the Appalachians rise from the Blue Grass
Depending on the "density" of your weave, you may increase the length of material needed by up to 40%. Consider if the corresponding increase in resistance may be a factor.
I used the same weave for longer runs through my attic out to patio speakers.
Old 16th December 2008, 04:51 PM   #3
Length won't be (so big of) a problem, the cables will only have to be 2m / 7ft long, tops. I was fearing something more like interferences between the woofer and the tweeter signals...
Old 16th December 2008, 11:00 PM   #4
http://www.tnt-audio.com/clinica/triple_t_e.html
How much would you pay for braided cat 5 speaker cables? fiveliter Everything Else 5 28th April 2007 01:10 PM
Questions about making Cat5 speaker cable wixy Everything Else 1 10th March 2007 06:57 AM
braided tonearm tade Analogue Source 2 24th June 2006 08:37 PM
braided speaker wire DREW028 Subwoofers 3 6th April 2006 10:08 PM
diy Braided Cables karma Everything Else 4 27th May 2004 04:11 PM
Copyright ©1999-2013 diyAudio
