Old 15th December 2008, 06:20 AM   #1
Default The China Syndrome (sister project to Orient Express)
After much nagging by the DIY community, the China Syndrome has arrived.
They're ready for public viewing. The crossover looks very similar to the Orient Express, but I had to cross lower, which means component values are larger, which means the total cost goes up a bit. Still, you should be able to get away for less than $110 using normal parts (Bennic capacitors and Eagle resistors). Sorry! You spend less on the driver, only to spend a bit more on crossover components.
But these were definitely optimized to milk the most I could from these ultra-budget drivers and get a clear, articulate midrange. Should make some nice bedroom bookshelf or HT speakers.
http://undefinition.googlepages.com/diy-chinasyndrome
Sorry no BOM yet. I'll try to get one together soon. Any questions or comments, fire away!
-Paul Carmody
https://sites.google.com/site/undefinition/diy
Old 16th December 2008, 05:01 AM   #2
The BOM is up. Turns out I was actually a bit off in my guesstimate on the parts cost. These will be between $90-$100. (psst... Madisound has these surplus "Tyee" 10 uF polypropylene capacitors for 90 cents apiece. Great bargain. My only complaint is that the leads are a little fragile; but this won't be a problem once you glue/strap the caps in place and solder everything together)
Linky: http://undefinition.googlepages.com/...yndromeBOM.doc
-Paul Carmody
Is the E86L the industrial sister of the EL86? bembel Tubes / Valves 19 20th December 2006 09:13 PM
My sister's project darkfenriz Everything Else 9 3rd May 2005 01:45 AM
James 2.5K/3.5K/5K, 10W/20W Orient Hi-B Transformers $129/$189 a pair tankhinhow Swap Meet 0 15th October 2004 01:58 PM
At last! Hope for the victims of 'White Van Syndrome' 7V Multi-Way 51 3rd December 2003 01:28 PM
Page generated in 0.05944 seconds (76.82% PHP - 23.18% MySQL) with 10 queries
