The main setup consisting of cd transport – converter – preamp – active x-o – 2 power amps are connected to bi-wired 2 way speakers. Recently, acquired multi-channel digital av receiver which is also capable for bi-wiring. Actually, av-receiver with remote control is very handy for quick listening, morning news etc., so I would like to use it also on the main speakers.
I believe that the best but more complicated solution should be to made kind of switch box which will totally, disconnect output from the main setup and than connect the output from av receiver. I am wondering, if the speaker wires from both, the main set-up and av receiver are connected parallel to the speaker terminals, provided that only one system is turned on, whether it could be some negative effect or possible damage on the other amp/av-receiver which is turned off. |
#2 | |
Instead: Install the appropriate switches to make sure that connection never be established, Make a DIY switch matrix or purchase a commercially available A/V switching matrix |
#3 |
Yes, I thought so. Thank's very much for reply HK,
best regards |
| Connected speaker wires from one amp into another... | buzzman | Solid State | 2 | 2nd January 2007 01:52 AM |
| Not connected yet | Andy G | Multi-Way | 2 | 14th October 2006 09:20 AM |
| Australian speaker parts sources | ooty_boy | Full Range | 0 | 10th November 2005 03:47 PM |
| Audio VU meter connected to speaker output? | PatPet | Pass Labs | 8 | 11th June 2004 01:36 PM |
| Must I have a TV connected? | Timn8ter | Digital Source | 2 | 16th March 2004 06:27 PM |
| Page generated in 0.07864 seconds (74.72% PHP - 25.28% MySQL) with 10 queries |
