Eton Empire with AMT and "ceramic" housing - Page 3 - diyAudio
Old 8th April 2003, 08:43 AM   #21
Lucas_G is offline Lucas_G  Netherlands
In the original plan, the satelites have an internal volume of only 30 liter for both 17cm speakers. In my housing they have two times 20 at their disposal. They are sealed cabinets, by the way...
So not much bass, but splendid "impulse-behaviour?"..
This is the look of the original housing:
Old 8th April 2003, 08:51 AM   #22
Here are the components used per speaker:
Loudspeakers (Chassis):
2 piece of 7-360/37 Hex/Eton
1 piece of ER 4/Eton
Filter (L/mH; C/F; R/12):
1,0 mH Tritec L37 x 0,80; 0,14Ω L1
0,39 mH LU 32/36; 0,71 Ω L2
0,47 mH LU 44/30; 0,436 Ω L3
3,9 F MKP Audyn Cap/250 Vac C1
10,0 F MKP/800 VDC C2
1,5 Ω MOX 10 W R1
Instead of the tritec, I used Mundorf OFC Copper Foil CFC 10
1.0 mH 0.14 Ohm
http://www.mundorf.com/english/bauteile/frspule.htm
Instead of the Audyn Cap, I first used Mundorf Extreme cap, then I switched to Jensen paper in oil caps.
Here is the layout of the filter:
Old 8th April 2003, 11:36 AM   #23
Ouch.... this isn't a cheap project Hopefully it sounds as good as the sum of the raw drivers. What do you have in mind for the <100Hz region?
Old 8th April 2003, 02:43 PM   #24
hi!
did you hear any difference between the mundorf surpreme and the jenden paper/oil capacitor? Could you post your impressions?
greetz,
garnex
Old 8th April 2003, 08:17 PM   #25
Originally posted by LaMa
Ouch.... this isn't a cheap project Hopefully it sounds as good as the sum of the raw drivers. What do you have in mind for the &lt;100Hz region?
It wasn't cheap indeed, but the Eton 17 cm drivers are really very good. Very stiff and therefor cleansounding without a lot of breaking in the higher frequencies and that is why they sound so clean and neutral without becoming harsh.
The little air-motion-transformer is much better than any dome-tweeter I have ever heard: Very fast and open without screaming. The large AMT and some very large Ribbons are a little bit better but they cost a few times more.
All in all I am very pleased with them. There are no commercially available speakers that I know of that I would prefer.
I didn't built them myself to safe money, but to find something up to my taste. I am a recording engineer in classical music and I wanted to have something good in my home as well, that enables me to hear detail and space in recordings, be they made by me or others. Most speakers have difficulty in this because they colour too much.
For the bass, I am still considering various designs.
Any suggestion is welcom, of course!
Greetings,
Lucas.
Old 8th April 2003, 08:18 PM   #26
Originally posted by garnex
hi!
greetz,
garnex
Hi Garnex,
I do have some impressions on that, but I want to do another comparison on that now that both caps have breaked in.
I will let you know after my second comparison, al right?
Lucas
Old 9th April 2003, 11:56 AM   #27
You already know this design? (unfortunate only in Dutch )
It's a closed enclosure of 45l with a 8" eton driver (8-472/32 HEX ) With a plate amp (tomessen). Each channel his own sub.
Old 9th April 2003, 01:53 PM   #28
alright! thanx in advance,
garnex
Old 10th April 2003, 05:01 PM   #29
I see that I failed to mention the measures of these speakers:
They have 26 cm width, 57 cm height and 59 depth. The black colour make them look somewhat smaller, I guess.
They weigh 45 Kg a piece and the netto volume of each speaker is two times 20 liter.
Lucas
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
Wanted: Empire 12" Woofers ARRAY Swap Meet 1 20th September 2009 03:54 PM
FS ceramic balls 3/8" decky Swap Meet 0 11th March 2008 10:34 AM
Trade: Eton 5" & 7" gengis Swap Meet 1 4th November 2007 03:32 AM
Ceramic/Eton Transmissionline speaker Jan Deckers Multi-Way 7 13th August 2004 11:07 PM
Copyright 1999-2017 diyAudio
