prefered crossover freq for scan speak 9500's
This seems to be quite a popular tweeter, i aminterested in your prefered crossover frequency for use in a small two way speaker 14L Cabinet.
The woofer is a seas 17rcy-p, i am not convinced by the sound (seems thin but vocals are great )
so, i thought that the cross over frequency may be incorrect, and maybe the tweeter needs to be attenuated, the bass may be there but to quite compared to the higher frequencies.
I do not know what the cross over is at the moment is is borrowed from a pair of Gale :dodgy: two ways, hence my thoughts about doing the crossover properly. or am i trying to make a silk purse from etc etc etc...
or are the seas not suitable for this aplication 9 they were recomended to me as replacemnt for the ex002!! )
Mark
Thanks, for your advice, will some thing like winisd be ok for working out the component values?
also i guess that you do not want the crossover freq to be the same for the low pass as the high?
Please excuse if these are simplistic questions, i am just starting!!
I think i will start with the crossover to go with the woofers i have and look at the others on model software, what sort of response / shape are you looking for on the graphs, smooth or going for lowest frequency at the -3db point :confused:
Mark
:eek: :eek: :eek: :eek: WOW :eek: :eek: :eek:
i have just removed the naff crossover and put a simple 4uF cap on the tweeter...............i didn't realise the tweeter was that good...
right must order parts for the crossover........hmmmm and mayby new woofers and cabinets.....
ho hum i guess i have been lurred into this amazing world!!! ;)
hi sorry been away for a while. i changed jobs and my Inernet access was company owned ;)
right i seem to be going in the right direction (or am I ???) the thin sound seemed to be coming from "too much" tweeter,
I have put a resistor in series of 25 ohms to attenuate it. I am now concerned that my initial crossover is way out, is this too much resistance for the tweeter?
The cross over is a second order with 1 off 4.7uF caps and 1.02 mH inductors for the tweeters and the same again on the woofer. (clearly in different configurations ) these values were used from a calculation website i found.
Instead of using such a large resistance is there another way, i am sure this has removed some of the "sweetness" of the tweeter.
mark
try a Rp of 10 ohms and a Rs of 4 ohms for a start. reduce Rs and increase Rp accordingly.
remember that the effective impedance of teh tweeter and L pad must be used for teh XO freq.
ex: 8 ohm tweeter, 8 ohms Rp, 2 ohms Rs gives 6 ohms that the XO "sees".
Rp is reisitance in parallel with tweeter, Rs is resistance in series with combo or tweeter and Rp.
hope this helps.
