Old 11th December 2008, 09:06 PM   #1
Klimon is offline Klimon  Belgium
Default Importance of Vas in TL-loading
Looking for a midwoofer to use in an existing cabinet I've found a candidate with near-identical Fr and Qts compared to the woofers the Tl cabinet was designed for. However Vas of the original woofers is 15; the new woofers state 25l. Will this work properly or if not, what can I tweak to the cabinet to suit the higher Vas?
Thanks!
Simon
Old 11th December 2008, 09:30 PM   #2
GM is offline GM  United States
GM's Avatar
All else being equal, increase Vas and cab Vb must increase proportionately, so double Vas, double Vb for a given alignment, ergo the TL will be too small in cross sectional area (CSA) for the new driver to work optimally, i.e. once stuffed it will have a higher F3, F6, etc., but depending on the room, etc., it may still perform well, though only one way to know for sure.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
Old 12th December 2008, 10:59 AM   #3
If the Fs of the drivers is the same this implies the 25L Vas driver
has a lighter cone or a larger effective radiating diameter than
the 15L Vas driver, either way as GM said, a bigger cabinet.
What is the Fs and Qts of the original driver ?
/sreten.
Old 12th December 2008, 02:41 PM   #4
Fr= 55hz
Qts= 0,52
It's hard to find a driver with same Fr+Qts+Vas as the original; another driver has matching specs except for Qts of 0,4. if Fr dictates length of the line and Vas=diameter, where does Qts come into the equation?
Thanks -- Simon
Old 12th December 2008, 03:03 PM   #5
See measurements at Zaphaudio.com
Hi-Vi F6 is very near, the Tangband-W5-704D not too far away.
this is all assuming the TL does match the specifications.
You can check that here :
http://www.quarter-wave.com/TLs/Alignment_Tables.pdf
Which also illustrates the effect of Qts with Fs and Vas fixed.
/sreten.
Old 12th December 2008, 03:25 PM   #6
GM's Avatar
Basic max flat reflex box formulas:
Vb = 20*Vas*Qts^3.3
Qts = 0.403412*(Vb/Vas)^0.303
Vas = 0.05*Vb/Qts^3.3
original driver:
55 Hz Fs
15 L Vas
0.52 Qts
Vb = 34.668 L, so assuming these specs are ~accurate, then your goal is to find a ~55 Hz Fs driver with a Vas, Qts combination that yields approximately this Vb with the understanding that a lower/higher Qts will raise/lower F3, F6, etc..
GM
Old 13th December 2008, 11:08 AM   #7
Hi-Vi F6
The TL I'm talking about is 's3tml' from IPLaccoustics.co.uk who formerly used a custom designed driver and now the HIVI m6a, be it with slightly differing specs. What I'm looking for is a driver that works in the given cabinet, has highish efficiency and a relatively smooth midrange. The TB you suggested looks like a peach but is a 5" woofer vs the 6,5" original. Should I make an adapter to ammend the existing hole, wouldn't the change in piston area still affect TL behaviour?
Thanks, that gives me something to work with.
Thanks again guys, much appreciated.
Simon
Old 13th December 2008, 04:35 PM   #8
GM's Avatar
You're welcome!
Where in the formulas I posted is driver Sd included? If you're referring to MJK using Sd as a reference to defining a TL's, etc. cross sectional area (CSA) it's just that, a reference, and if you use his old worksheets that have this default I recommend converting them to either a width x depth or area dims to save yourself a step in the calcs.
Anyway, Sd only affects its peak SPL rating, which can be compensated for by increased Xmax and/or power handling, so assuming it has enough of each to suit you regardless of whether it measures up to the original, then it's a viable alternative.
GM
Old 13th December 2008, 09:55 PM   #9
Excellent. The closest thing available in Europe is this http://www.juoiga.nl/download/w5-1611.pdf
Widerange so will certainly allow for a first order at 3k or so.
Cheers
Simon
op amp importance in a pre-amp GratefulTony Solid State 23 21st August 2009 10:54 PM
The Importance of Being Biased Nelson Pass Pass Labs 74 26th July 2007 01:58 PM
Anode Loading Vs. Cathode Loading ? valveitude Tubes / Valves 19 22nd July 2005 10:00 PM
The importance of CCS in Aleph-X Andypairo Pass Labs 11 8th September 2003 05:54 PM
Page generated in 0.10495 seconds (79.54% PHP - 20.46% MySQL) with 10 queries
