Banned
I'm in the process of turning 2 ways into active three ways. The current drivers are:
Bass Peerless 830868 8" Data Page Tweeter Vifa D25 TG-55 1" dome Too old even for archives These are also up for review at some time way in the future, but the the current issue is the choice of a mid-range driver. I would like to use the mid-range to cover 300 to 3,500 Hz which I appreciate is a big ask. The contenders are; Peerless 830854 Data page Peerless 832873 Data page Vifa PL11MH09-08 Data page Can I ask the opinion of forum members which they consider the 'best' and for what reasons? I generally play rock and, yes, I do have a fondness of 'loud'. Thanks Frank |
#2 |
I think the "loud" comments makes me lean toward the 5" nomex, just that little bit more oomph than the other two. The Nomex's are rather nice , too
ps.. you got the link to the PL11 wrong, but that's ok, got all the data here. |
#3 |
Banned
Thanks Andy,
So the 300 and 3500 Hz are OK? And does it 'sound' as good as the other two? Frank |
#4 |
HiFrank, the only further comment i'll make is this: - if you are thinking of replaving the woofer in the future pick the mid that will work with the new woofer, and if you are happy with the existing Peerless 8 then perhapsmyou should look at a bigger Peerless driver.
Or add another driver fot a 3.5 way system, as you know I rather fancy the 3.5 way using a bigger woofer crossed very low for the .5, as your bi-amping maybe that isn't possible, but you could play around with sealed box tuning to give the desired effect.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING" |
#5 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#6 |
Even though the tweeter is unknown, (are you sure its not a D27 TG?), I'd say it would be nice crossed at 3k, and any of those mid drivers will be good to 3k even with a very simple low order x-o.
Look at the 3-way linked series x-o stuff on my site, you may find it the simplest way to get REALLY nice sound , and any of those mid drivers, with that woof and tweet, should work rather well with that style of x-o http://members.optusnet.com.au/~grad...ss-overs8b.htm |
#7 |
Banned
Andy
The cross-overs are active; the 24dB per octave P09 from Rod Elliot feeding into LM3886 P19 modules from Rod as well. Frank |
#8 |
FWIW, my thoughts WRT the basics of how to choose a mid driver: http://www.diyaudio.com/forums/showt...92#post1679992
For 'loud', the 'filler' mid is preferable, but if you're determined to go wide BW, then for loud rock or similar I recommend using a prosound or at least a high power HIFI mid suitable for XOing at least -12 dB outside the desired 300-3500 Hz BW in your case, i.e. a ~flat BW to ~212-4950 Hz if 4th order. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#9 |
Banned
I thought this question may have genertaed a bit more of a response.
#10 |
Perhaps this is because at Christmas every-one is thinking more about presents and parties.
If money was no object you could buy them all and build lots of test boxes and pick the one that works/sounds best to you. There are other choices from different suppliers, but any one of those drivers would be suitable as a mid in a high quality 3-way. Sometimes you just have to build it and listen. Regards and Merry Christmas and other seasonal and religious celebrations as well Ted
| Drivers frequency range | qguy | Subwoofers | 4 | 17th June 2008 12:55 AM |
| Need help to choice Drivers for 3 Way System! | samsagaz | Multi-Way | 10 | 13th July 2006 07:49 PM |
| Peerless Drivers ... Wise Choice? | HTRookie | Multi-Way | 7 | 12th December 2005 12:58 PM |
| full range drivers.... | navin | Multi-Way | 0 | 8th December 2003 06:00 PM |
| Page generated in 0.10712 seconds (79.73% PHP - 20.27% MySQL) with 10 queries |
