Yepp, has anyone any experience with this driver in some sort of TL? Says in the spec sheet that it's not a bad idea.
I don't know how to calculate one myself but I'm willing to be the bronze if someone else is the brains! http://www.seas.no/index.php?option=...189&Itemid=186 |
#2 |
Anyone?
#3 |
I've used the W18E and W18EX in a TL and both are quite impressive, the W18E with higher Qts give a lower bass response but I prefer the EX in the higher frequencies. Looking at the L18 specs and construction, I believe it would give you a bit of both.
#4 |
Sounds good, the problem is that I don´t got the skills to calculate TL's. Have been lurking around the net for a build but I didnt find any. Suggestions anybody?
#5 |
Greets!
What do you have in mind, a fairly high tuned maximally flat alignment or one tuned to Fs or somewhere in between? GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#6 |
I was thinking of reaching low (fs) and crossing them over active at 2000 hz with the vifa xt25tg30. But I haven´t and are not able to do any sims so i don´t really know how "unflat" alignment that would create?
#7 |
Greets!
Here's three alignments based on various design trade-offs to choose from since from my POV the high tuned TL best meets the usable bottom end, but you may mean a near IB one (Fs tuning) or even somewhere in-between. All dims approximate, L = axial pipe length, CSA = cross sectional area of pipe, zdriver = location from the closed end and simmed stuffing density is based on using loose polyfil which according to MJK isn't accurate since it exceeds 1.0 lb/ft^3, so strictly a starting point for experimentation: 36 Hz Fp: L = 89.937" CSA = 31.125"^2 zdriver = 31.375" stuffing density = 1.0 lbs/ft^3 56.16 Hz Fp: L = 56.125" CSA = 41.500"^2 zdriver = 19.562" stuffing density = 1.25 lbs/ft^3 115.38 Hz Fp: L = 26.000" CSA = 68.00"^2 zdriver = 9.06" stuffing density = 1.75 lbs/ft^3 Looking forward to a review plus final design details! GM
#8 | |
#9 |
HI FYI,
Another good use of the Seas L18 is IMO a T-TQWT:See the picture b |
#10 |
Thanks a lot GM!
So this tells me that the opening at the end must be 31.125"^2 for the 36 hz aligned line. Is the line relly just a cone and it goes from zero to 31.125"^2 with a hight of 89.937"? |
| Seas 27TDFC H1189 vs Seas 27TFFC H881 | ermes | Multi-Way | 4 | 19th April 2011 01:20 PM |
| chooseing Seas Cygnet or others seas kits | juanito | Multi-Way | 0 | 20th July 2009 12:27 PM |
| Wanted: Seas W17EX001, Usher 8945P, Seas CA18, or somewhat similar mid-woofer. | Spasticteapot | Swap Meet | 2 | 7th March 2007 04:06 PM |
| Seas Millenium tweeters and Seas W22EX-001 | sephiroth619 | Swap Meet | 2 | 5th March 2007 06:34 AM |
| Seas Excel W26 compaired to Seas L26 (10") | harruharru | Subwoofers | 9 | 11th March 2005 09:47 PM |
| Page generated in 0.12114 seconds (76.97% PHP - 23.03% MySQL) with 11 queries |
