Hello,
I know this may sound like a simple (stupid) question, however, when using a tweeter of 4 ohm and woofer of 8 ohm, do any of you use the L-Pad configured to bring the tweeter to an 8 ohm resistance? or leave it at 4 ohm? Thanks for the guidance... |
#2 |
I have never use an L Pad configuration, never needed to as I have always used (tried to match) same rated resistances drivers. But I can say I would not leave the tweeter as 4 ohm as it will more likely blow up when you but more power into it.
Anther thought if the woofer was say 30 watt rms and the tweeter 60 watt rms then may be that would be OK? A few more details may help. |
#3 | |
The final tweeter resistance should set it to the right level for the crossover design, usually this means attenuating the tweeter and increasing impedance is a good idea. THe L-pad parallel section damps the tweeter and it is usually a trade-off between impedance and damping. http://www.rjbaudio.com/Audiofiles/FRDtools.html http://www.geocities.com/woove99/Spk...esigningXO.htm http://www.zaphaudio.com/ http://www.rjbaudio.com/projects.html http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm http://htguide.com/forum/forumdisplay.php4?f=39 http://www.humblehomemadehifi.com/ http://www.linkwitzlab.com/ http://www.geocities.com/kreskovs/John1.html |
| Can a 8ohm driver be mated with 4ohm tweeter? | Nordic | Multi-Way | 10 | 2nd October 2007 11:53 AM |
| 4 Ohm woofer 8 Ohm tweeter | Tennessee Jed | Multi-Way | 4 | 22nd April 2006 12:13 PM |
| Alesis M1 amps w/ 4ohm woofer | AJinFLA | Multi-Way | 1 | 12th May 2005 06:04 PM |
| is this tweeter alright with this mid-woofer | busterno1 | Multi-Way | 2 | 27th March 2004 02:46 AM |
| 4ohm woofer and 8ohm tweeter. | JoeBob | Multi-Way | 4 | 5th December 2001 01:45 AM |
| Page generated in 0.07687 seconds (72.24% PHP - 27.76% MySQL) with 10 queries |
