Hi!
As stated above I want to go from the tangband 28-847s tweeter I'm currently using to the more soffisticated (?) vifa xt25sc30-04. Since I'm a total rookie in constructing crossovers I'm hoping for some help from this place! The current crossover looks like this: Specs for the vifa: VIFA XT25SC30-04 SHIELDED DUAL CONCENTRIC DOME TWEETER $80 ea. SPECS: 100 watts RMS/140 watts max, Znom: 4 ohms, Re: 3.0 ohms, Freq. range: 1,500-40,000 Hz, Magnet weight: 8.5 oz, Fs: 500 Hz, SPL: 91.5 dB 2.83V/1m And for the TB: http://www.tb-speaker.com/detail/1208_03/28-847se.htm Glad if you can help me! |
#2 |
Where did you get the crossover schematic?
#3 |
I forgot to tell you in the first post that I alrady have a pair of speakers up and running with that crossover which I got from a memeber at a swedeish DIY audio forum. The reason why I'm changing the tweeters is simply because I got them very very cheap and they are waiting for another project.
From my rookie point of view the things I have to deal with is that the vifa is 4 ohm and a bit more sensetive. The xo point at 3 khz chould work and more compensations in the filter I don't think I need right now. |
#4 |
That is a near bog standard "textbook" crossover that does not consider the drivers used (much, only the zobel if it matches). Consequently changing the drivers will not matter much. Its not a 2nd order L/R crossover as c/o's are acoustic. It is near L/R electrical but electrical is not acoustic. http://www.rjbaudio.com/Audiofiles/FRDtools.html http://www.geocities.com/woove99/Spk...esigningXO.htm http://www.zaphaudio.com/ http://www.rjbaudio.com/projects.html http://www.troelsgravesen.dk/Diy_Lou...r_Projects.htm http://htguide.com/forum/forumdisplay.php4?f=39 http://www.humblehomemadehifi.com/ http://www.linkwitzlab.com/ http://www.geocities.com/kreskovs/John1.html |
#5 |
So it doesent matter that they differ in impedans? If I would like to damp the tweeter a bit moore what value would you recommend (instead of the R2 1,5 ohm resistor right?)?
#6 |
Yes it does matter they are different impedances, though where 16ohm "Zo" for the TB comes from I'm not sure. The fact is the "8ohm" L/R network might work just as well as changing it to be "4ohm" L/R, you do not really know. The crossover for a start has no baffle step compensation. Your bass/mid might have breakup modes glossed over by the writing speed of TB's frequency response plot. Look at this design, c/o is 4th order L/R acoustic. http://www.zaphaudio.com/audio-speaker17.html |
#7 |
I wouldn't bother to swap the tweeters. According to my rough simulation, the actual xover point is around 3.5 k - 4 kHz. The Tang Band tweeter should be adequate for this task. You won't hear much difference by replacing it.
| Modifying an Original Richter scale crossover ??? | scutterflux | Solid State | 2 | 30th June 2008 06:06 PM |
| Dayton RS 7"/ Vifa XT25 tweeter Crossover | LukeDuke | Multi-Way | 4 | 13th February 2008 05:39 AM |
| Modifying Behringer CX3400 crossover | OzMikeH | Parts | 16 | 6th January 2008 05:33 PM |
| xt25+ pl18 4ohm enclosures n crossover | xmutan | Multi-Way | 9 | 28th August 2005 04:13 AM |
| Modifying Crossover Advice | BigMacX | Multi-Way | 2 | 6th August 2002 08:49 AM |
| Page generated in 0.09487 seconds (76.67% PHP - 23.33% MySQL) with 10 queries |
