hey guys,..
i'd like to amplify sound from mp3 to the speaker, i've made the amplifier circuit. and i use Skytronic 902.296 mid range speaker with frequency response (300 Hz- 12 KHz) and I add bandpassfilter to fulfill the frequency response, and it worked. the problem occurs when I change my speaker to FR12-8 full range speaker with frequency response(f(-10db) 70-18000 Hz when i tried to change my filter, the sound from the speaker is really small, and not good. and i adjust the filter with cut off frequency in -10db, is sounds better but not perfectly in treble sound.. somebody can help me? what is f(-10 db) means? is it not in -3 db? |
#2 |
Hi, F-10 = the -10dB downpoints. There is not need to add a further -10dB bandpass ciricuit. Rated power 15 W Maximum power 40 W Nominal impedance Z 8 Ohm Frequency response 70–18000 Hz Mean sound pressure level 85 dB (1 W/1 m) Maximum cone displacement 5 mm Resonance frequency fs 110 Hz Magnetic induction 0,8 T Magnetic flux 150 µWb Height of front pole-plate 3 mm Voice coil diameter 20 mm Height of winding 4,5 mm Cutout diameter 114 mm Net weight 0,284 kg D.C. resistance Rdc 6,8 Ohm Mechanical Q factor Qms 5,61 Electrical Q factor Qes 2,8 Total Q factor Qts 1,87 Equivalent volume Vas 8,7 l Effective piston area Sd 87 cm² Dynamically moved mass Mms 3,8 g Force factor Bxl 1,7 T m Inductance of the voice coil L 0,22 mH Heat resistance −25 ... 70 °C With a Qts of 1.9 outside a box you can use it open baffle or with some bass filtering in a 7 to 10L box. The treble end could be shelved down for better balance. |
#3 |
but i dont quite understand with this sentence ("With a Qts of 1.9 outside a box you can use it open baffle or with some bass filtering in a 7 to 10L box. The treble end could be shelved down for better balance. ") do u mean i dont have to add filter to get the appropriate response frequency? |
#4 | |
If you want to use this driver in a closed box, the alignment (interaction box and driver) is not optimal, therefore you need some sort of high-pass filter to get it right. An alternative could be a box with additonal holes (controlled leaking), such that you do not have to add additional filtering components to correct the box alignment In all cases it is adviced to add a parallel LCR (coil, capacitor and resistor in parallel) in series with the driver to tailor the high frequencies for the proper SPL level (better balance). |
#5 | |
so if i want to use this speaker in closed box, i need that high pass filter right? do i need low pass filter also , in order to keep the high frequency within the frequency range? |
| Car speaker problem | Pintu | Car Audio | 2 | 14th November 2008 04:01 PM |
| esl 63 speaker problem | brobarrie | Planars & Exotics | 1 | 10th July 2007 02:04 PM |
| Problem with JBL speaker system | John Hope | Car Audio | 2 | 3rd June 2005 01:31 PM |
| speaker problem | Xplorer | Car Audio | 1 | 9th June 2004 10:29 AM |
| What's the problem - amp or speaker? | Nuuk | Chip Amps | 12 | 14th June 2003 08:35 PM |
| Page generated in 0.09631 seconds (79.79% PHP - 20.21% MySQL) with 10 queries |
