Old 4th December 2008, 04:51 AM   #1
Moondog55's Avatar
Default My 3-way OB new project
OK i'm asking for help to start off.
I have bought some cheap MDF and that is going to set my baffle size, I've played with some programs and apart from the poor power handling the responses I get look reasonably good.
I am looking now for some advice on possible modifications/tweaks to the cheap bass drivers I'll be using.
Aussies will know Jaycar, and some may be familiar with their CW-2125, it is a stamped steel frame with the book T/S parameters Fs 32; Re 7.2; Qms 4.00; Qes2.32, which makes Qts 1
.46.
Vas is 166 litres
Thermal power handling is stated as 50watts but X-max is only 3.5mm/7mm P-.P.
If I modify the baskets where should I start??
Is there a best order in which to work?
I have considered filling in the gap between magnet and basket first using epoxy filled with Aluminium powder ( because I have lots of that ) and then lining the spokes with some stick-on felt, followed by some damping on the frames, using cost effective means ( funny but epoxy may work out cheaper than blue-tac ) and then some cautious PVA on the cones.
I have had sucess with PVA coating these drivers in another project.
Baffle size is 1810 X 455mm and can be as thick as I want using multiple layers, depth of side walls now open to discussion.
QUOTE" The more I know, the more I know, I know (insert maniacal laugh >here<) NOTHING"
Old 4th December 2008, 09:11 AM   #2
SimontY is offline SimontY  United Kingdom
SimontY's Avatar
Send a message via MSN to SimontY
Hi Ted,
Is the PVA to reduce Fs or to help control breakup? Those specs look wonderful for OB use already, and 3.5mm xmax is not too shabby IMO. With 2 x 12" per side they should give plenty of volume displacement.
I've never done a lot of driver modification but bitumen/tar on the basket spokes should effectively damp any ringing. I don't know how relevant this is on a woofer that will be used low down, but I intend to do my cheap OB woofers like that.
What are you baffle dimensions likely to be?
Will you be considering transformer-bass?
Simon
Old 4th December 2008, 09:12 AM   #3
Stuey is offline Stuey  Australia
I'll be interested to see how those Jaycar's go, Ted!
What is the sensitivity rating of those?
Stuey
Old 4th December 2008, 12:02 PM   #4
Moondog55's Avatar
Hi Simon
PVA to reduce cone break-up by making cones just a little stiffer is the intention, but adding a couple of grams will also reduce resonance a tad.
Hi Stuey
Jaycar specs are 92dB 1W/1M, X-baffle shows 90db at 45Hz which is more important, slight rise to 100 and a steep fall-off and big dip at 300, but 300 or close too is where I intend to put the Xover so I'm going to need some help there.
I don't hink I'll be using T-base with these WAF on the added expense and all.
How-ever if they don'r perform all that well I can add it at a later stage.
The cheap off cuts are 455 X 1810mm and I have 24 of them so I can make this baffle as thick a I like, I ca even use the Frankenstien trick" to curve them id I use the 8mm stuff and not the 12mm.
It is the depth of the side wings that is going to keep me awake at nights, to deep and the mids may have trouble too shallow and I loose bass, and I'm still thinking about that big sealed 15inch sub from 40Hz down, which effectively makes this a 4-way systemwhich means I have to go active at leaast for the bottom 2 crosses 40--.. 200/300 or thereabouts
Old 4th December 2008, 12:08 PM   #5
Moondog55's Avatar
Simon please note thats 4 per side, I'll be using the standard layout WW MTM WW, but offsetting mids to one side and trying my hardest to get MTM spacing as tight as possible, I have thought about insetting the tweeter and laying the frame of the Vifas over the top but that may be too hard
Old 4th December 2008, 12:15 PM   #6
SimontY's Avatar
4 per side! Why on earth are you fretting about xmax? You'll have loads of bass with these monsters.
WWMTMWW sounds like a real challenge to build. You don't want any wings behind the mid drivers so you'll need some that start deep and go in, then flare out again at the top.... or something like that. Another option is sealed mids, as the OB loading is most useful for the bass (an odd option but not without merits IMO).
T-bass is very helpful for SQ and deep bass but you're quite right, it can easily be retro-fitted. Just keep your eye out for cheap ~500VA transformers in the meantime, I don't think you'll regret it.
Simon
Old 4th December 2008, 12:36 PM   #7
Moondog55's Avatar
Well I did some sim-work on the mids and getting to 110dB seemed to be possible but the bass can only go to 105 before the voice coil pops out, and my assumption was that IF i needed to do any BSC I'b prefer to do that in the bass, I hate the thought of padding down the mids.
If I do have to pad down the mids I'll maybe do it by running them in series rather than in parallel, but in parallel I get that extra 6db and I loose that in the bass by running series/parallel.
Those p-13's are only 88dB/1W/1M factory spec.
This is why I asked for help, 3-ways are HARD when you want to get them almost right first time and at $95- each I wanted to do the Vifa midrange justice.
It's enough to make you start tearing your hair out, and I don't have that much left.
Old 4th December 2008, 12:38 PM   #8
SimontY's Avatar
I hear you, but it isn't really baffle step on an open baffle, it's just a big lumpy mess instead!!
Old 4th December 2008, 12:54 PM   #9
Moondog55's Avatar
ROFLMAO
indeed
At least i can concentrate on making them sound Ggooooodd rather than maximise WAF by making them "pretty"
It was SWMBO who bought me the P-13's after all.
One of thes days I'll have the money to do a really efficient system so that we can listen to symphony's at "live" level but by then we'll both be living in a sardine can and won't have the room.
There used to be a 15inch version of these woofers ( 15 years ago they had a Qts of 1.56 ) 4 of those a side would have been good too
Old 4th December 2008, 01:00 PM   #10
SimontY's Avatar
lol @ SWMBO - new one to me but I could guess what it meant instantly
I'm sure you'll get great SPLs close to the "live" sound, and because it's OB the bass won't be lagging behind.
I'm surprised by your decision to cross over so high, I've not seen many OB 3-ways done like that, but it should keep the mids clean. I just worry about having too strong an upper bass. It will possibly need to be EQ'd somewhat.
Simon
CDPRO2 Group Project (open source project) BrianGT Digital Source 147 8th August 2008 11:37 AM
My OLD Project....... cheap tube audio project!!! tube-lover Tubes / Valves 4 8th May 2008 09:26 PM
first project ceebmoj Full Range 5 23rd January 2008 07:51 AM
My first project, cool project. sorinsistem Solid State 3 19th January 2006 05:08 PM
Page generated in 0.13078 seconds (80.08% PHP - 19.92% MySQL) with 11 queries
