2.5 way versus 3 way - diyAudio
Old 6th April 2003, 06:31 AM   #1
Question 2.5 way versus 3 way
I'm a little confused. Perhaps someone can help me.
A 2.5 way is where the second bass/mid driver rolls off higher in lower bass, right? Say, rolling off at 100hz whereas the other driver may go down to 35hz. Both drivers however go all the way up to the tweeter's crossover. OK?
In the equivalent 3 way design the mid driver might roll off at 300hz and be solely responsible for the midrange.
So, is the point of a 2.5 way design to give bass extension or to boost midrange, or neither.
Thanks in advance.
Old 6th April 2003, 06:57 AM   #2
JoeBob is offline JoeBob  Canada
JoeBob's Avatar
In a 2.5 way, both bass drivers would go as low as they could, but one would be crossed over at the tweeter xover point, while the other would be crossed over lower. This is done for added bass.
ZRT 2 way versus 2.5 way s7horton Multi-Way 5 13th August 2008 06:23 PM
Two 6J5 versus one 6SN7 audiobliss Tubes / Valves 11 4th August 2008 10:25 PM
20% versus 43% screen tap ecl8220% Tubes / Valves 10 4th November 2005 09:16 PM
TPP versus PSE. GeirW Tubes / Valves 11 27th November 2004 08:55 AM
Active Sub versus Car sub massive_cranium Subwoofers 0 26th September 2003 02:18 PM
Copyright ©1999-2017 diyAudio
