Old 13th December 2008, 03:22 PM   #21
I actually found this site while searching for information on building crossovers. Some consider the entire endeavour evil, others a hobby unto itself.
If I go with a powered sub it should be pretty easy to just adjust its LP point to work with where the 901's naturally roll off.
The 901's actually measure about 7.1 ohms resistance not playing. Above it is mentioned that the Linaeums are about 6ohms. Since they are in different frequencies with some overlap the load may be tolerable.
Old 14th December 2008, 06:14 AM   #22
Pano is offline Pano  United States
Pano's Avatar
I just unpacked my Linaeums to check. They are indeed 6 Ohms. Says so on the bottom and an impendance sweep shows very flat 6 ohms from 20Hz to 10KHz - then a slight rise to 6.5 Ohms at 20KHz.
Call them 6 and be done.
You can use this page http://www.diyaudioandvideo.com/Calculator/XOver/ to figure your x-over.
E.G.
for 4K 1st order use 6.6uF
for 4K 2nd order LR use 3.3uF + 0.5mH
I hope to try mine on top of my current OB rig.
Have fun with the 901s!
Take the Speaker Voltage Test!
Klipsch KG4.5 with Linaeum tweeter Slothrop Multi-Way 2 6th May 2010 05:07 PM
Linaeum Dipole Tweeter as a Super tweeter? ktuuri Planars & Exotics 5 17th June 2008 07:52 PM
diy linaeum tweeter larc99 Planars & Exotics 1 22nd January 2008 07:54 PM
My linaeum tweeter does'nt work rhkwon Multi-Way 0 27th October 2004 01:57 AM
Where is Linaeum Tweeter goldyrathore Multi-Way 25 20th May 2004 07:02 PM
Page generated in 0.08006 seconds (69.84% PHP - 30.16% MySQL) with 11 queries
